Hey guys, did a search came up with ZILCH!
Well basically need to know how to remove that stubborn brake dust that basicalled welds itself onto my front rims.
Tried just soap and a toothbrush (yes a damn toothbrush) .. and no luck .. anything a lil more violent and rambo lols to remove this god damn nuisance?
Cheers
MRXTCZ
https://www.sau.com.au/forums/topic/246596-brake-dust-removal/
There's a crowd not far from you called D'Elegance at Auburn that have a wheel brush with bristles finer than a toothbrush but where those bristles are stronger too.
They also have a solution for wheel cleaning whilst at it. God_speed has used this method to great effect.
If something is baked on, Subaru carbie cleaner works to get rid of any residual. Your fingers can still get sore though.
After getting the wheels clean, the next concern is the microscopic pit holes that still remain on the wheels that'll pick up more brake dust all over again. So the wheels may have lost the clear film coating. Therefore the wheels may need to be re-coated and waxed.
Good son of rajab. .
Yeah they seem to have left not just holes .. but pits .. or craters may i add!
Really inconvinient and doesnt look very nice when looked at closely..
The build up is pretty bad, but they happen to all my rims. The stock R34 rims copped it aswell.
Well i'll give them a try, but recoating and rewaxxing? using what in particular?
MRXTCZ
I've had no troubles with cleaning brake dust off my rims since I stopped using bendix ultimates, it might be just coincidence though.
Use tar remover and polish the heck out of them, but if they're pitted it will be quite hard.
Hiya Vicky,
Having cleaned the wheels thoroughly - my wife won't let me put them through the dishwasher any more.
She's the one who complained about that great advert where the housewife donged her husband diy mechanic for cleaning his chrome rocker cover in his dishwasher, and the ad got banned.
Now where was I...?
Oh yes, after cleaning the wheels thoroughly, you can put each of them out in the sun and used masking tape to cover the tyres.
Then spray "Clear" onto the rims slowly and evenly as per instructions.
Apply a couple of coats.
You can then apply Canauba Wax over the wheels so that they don't gather brake dust any more.
Bendix Ultimates are renowned for their dust, my Legacy's wheels are horrid after just one week from them (and slotted rotors).
I've been told EBC greenstuff's are better with the amount of dust and still perform well.............
Edited by SNISMO
Hey Mr Xtc have you tried CRC Brakleen its good stuff and for the people in victoria is hard to get good brake cleaner due to the fact that the good brands are banned, Try different brands on the inside of the wheel first even try concentrated degreaser.
http://www.crcind.com.au/catalogue.nsf/web...en?openDocument
I'm one for using concentrated degreaser, but just make sure you don't leave it on for too long, tends to stain the wheel.
Cheers guys, just looking through the information here..
Well im gonna' firstly rip off all the wheels, give them a good scrub with sum degreaser in moderate amounts..
See how that goes and measure the craters lols. IF they are really large, then i will go with Terry's idea and apply the clear and then wax it.
But hopefully i wont have to.
Blonde question lols. Can i just turtle wax them after im done cleaning without the clear lols ?
MRXTCZ
Actually hehe, I meant that in the short-medium term, just waxing those spotless rims will protect them from brake dust infiltration.
When I watched God_speed spray his rims with Clear, that wasn't as hard as cleaning the darn things.
An earlier post said that heavy duty degreaser will work but you have to be careful not to leave it on too long or it can stain. I'd agree with that. The Kenco Truck degreaser can stain if left on too long. I found that the carbie cleaner didn't stain. It's just not good to absorb it through the pores of your skin.
Cheers,
Tez
BTW, you can buy a pack of latex gloves for your workshop from a $2 shop. They're good for working with chemicals as well as grease.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
