after finishing work today i arrived at the carpark to discover damage to my a pillar, above the drivers side window. I dont know how it happened, whether some amateur has tried using a scrwdriver to break into it?? i have no idea.
anyway im not sure whether it can be repaired or not. It seems to be only made of fibreglass, but a whole piece has been snapped off the panel.
Ive got a quote from riverside infiniti in the states for $US418 shipped which currently works out to be $640 aus.
Appreciate any help or advice!
https://www.sau.com.au/forums/topic/246690-help-a-pillar-damage/
Sorry to hear, it sucks seeing your pride and joy damaged. My rear bumper/nissan aero lip as well as my taillight was hit (presumably when the car next to me was reversing out) yesterday as well. Perhaps try japanparts.com (maybe cheaper than US) or ask around wreckers such as this one http://www.jappartswa.com.au/ (email - [email protected]) upon recommendation from DRIFTT.
From that photo it is very difficult to tell what is going on, it looks like it is fibreglass and that is easy to repair normally.
However if that is the driver's window and the damage is above it, I thought that would be steel.
Can you describe it better, or take a few pictures at better quality?
thanks for the responses guys.
yes it is the driver's side above the window, and its definately not steel. i still have the piece that was snapped off as it was sitting on the ground when i found it.
i guess i will just take it to a panel beater's to get a quote. Might give louie a call at xclusive colours
Edited by robbo33
If you still have the piece, do not lose it,
If it is steel, a good welder can fix and a re-paint is possible although difficult...
If it is fibreglass, many people can fix although strength could be a problem... and then it can be painted.
If it is Carbon (very doubtful - 1%) it can also be fixed similar to Fibreglass and painted.
Anyhow, don't stress it can be done, but I am afraid for it to look right a whole roof might need to be painted, and a good repair person may be needed.
Glass is the easiest to get right and a bit quicker.
Plastic? Really, that is even easier!!
Yep, your probably right with matching colour on 2nd look. I missed the rail...
Ooops..
If it is a coupe does the rear pillar get wide at the bottom of the rear quarter, that may be a bit harder but a good shop (as you said) should still have no problems.
so it is plastic. i thought so either that or glass.
anyone recommend a capable place to plastic weld this and decent colour matching?
how about luoie at xclusive?
also it has to be relatively cheap as i can order the entire a pillar panel painted same colour for $620 shipped from the states. i may be better off just doing this if the cost is to high to repair.
once again thanks for your help guys! ive got 20in works ready to be installed but want to get this fixed before i put wheels on!
ouch.
Hope you get it fixed mate.
Let us know the $$ damage in case it happens to one of us in the future.
Some asshole drove over the front bar of mine with a 4wd. Only a tiny scratch that I buffed out. The asshole even left the carwith his number plate on top of my front bar!!!
He was lucky that I didn't kick in the entire front half of his car before I drove off.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
