Beach To Burger Crusie Wrap Up 27/11/08
Just want to say thanks for everyone that made the night what it was. Lucky for us the weather was on our side. We had 20+ cars, an around 25+ people turn up $ ching ching $ now lets WHORE THIS THREAD UP an show them what they missed out on! :P
special thanks to the camera men:
RCHOO, BASTI, GAZAL
thanks to PAT AND KRIS that helped put it all together
hope to see you all at the '' show N shine '' this sunday 30/11/08
  • Replies 129
haha was good cruise, glad that it turned out all good. There were a couple of times we got split up, but the cb walkies helped us keep it tight :P
It was nice to see that we could squeeze 7 skylines through a green turn signal haha, if only every driver on the road was that alert, there would be no traffic :)
Burger's were awesome and lucky us for it being empty when 25+ of us rushed the little store haha
The waitress that AP smooth talked :) asked us how we formed such a large group, whereby dezz replied it was a skyline car meet and surprisingly she knew what type of car they are hehe
Nice photoshoot to end the night and a possible st.kilda motorkhana plan :D
Same time next week? :P
cheers
The **waiter** that AP smooth talked :P asked us how we formed such a large group, whereby dezz replied it was a skyline cat meet and surprisingly he knew what type of car they are hehe
Didn't know AP was into manlove, ur in Patria
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
