Yeah they have similair if not the same caliper as Ceffy and s13.
I plan to chuck Z32 calipers on mine...
I know no one in Australia has probably attempted it but the Cima is heavy as and definately needs a brake upgrade.
I have seen GTR calipers on a set of Y31 cima front coilovers
do you reacon new rotors will be needed or is it possible to use the original rotors
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-4298357
I will need new rotors and the car is 5 stud
maybe i should go to r33 disc and calipers? or R32 GTST disc and calipers somthing along these lines sorry i have taken so long to get pictures just been working getting other car ready for weekend
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-4301622
  • 1 month later...
Bump well the brake rotors are off and there a Hub style disc like the r31 but there 5 stud so this has chucked me right off knowing what would match it
there 260mm and the hub itself goes in stages.
so disc witdh is 24mm MIN then the hub is 31mm then there is a extra bit on the hub that is 19mm
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-4363312
  • 1 month later...
  • 3 months later...
  • 9 months later...
Win.
Rear brake pads I believe are DB1144, had a look at my pads when they were out and also a look at a picture of them. they appear to be correct and are of the same era as the cefiro. Pads listed are for Nissan Cima (check your bendix cat's)
can confirm this tomorrow when they arrive.
100% Confirmed part number for New rear brake pads by Bendix. DB1144GCT.
WIN!
I'd assume the fronts follow the same fashion.
Likely listed in Bendix catalogues as Cima, same same as A31 Cefiro but I do beleive A31/C33 front is exactly the same as SR20DET ? (there is some arguement about this).
Regaring direct bolt ups, S13 calipers would bolt up directly anyway, as should any Nissan caliper, R33 GTST and Z32 being the favorites.
Otherwise just take the whole knuckle assembly with 5 stud hub off something else and do a big 5 stud brake upgrade.
Do these use the same rear cradle as A31/C33/R32, etc ?
Looks a tad weird to me...
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-5199410
  • 2 months later...
no these use a r200 long nose, same as a hr31..
brakes are basicly r33 na brak, havent checked padsyet, they are not sr brakes, they use the same size rotor but with a larger 2 pot caliper. i have been playing since last post. i am just about to bolt s13 front hubs and shizz in with s13 coilovers. these brakes are actually a really good upgrade for stock sr rotors. and bolt straight on.
woo go me,
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-5344917
  • 1 year later...
Hey E-Z,
I've got a cima Gloria same colour and req a front disc rotor and wondering on some sort of substitute without doing the whole coil over upgrade as my airbag suspension and all electrics are working fine and it's still 100% original including the crocheted cima embossed head rest covers.
Cheers Tony
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-6237490
  • 4 years later...
so just found myself with another Y31 Cima
By the looks of it has been upgraded to the R33 NA rotors and brakes but I was looking at going for 4 pots as my spare Cima is now likely going to be used for the track.
also wanting to do a 4 stud conversion on my new road car to fit some old skool Rays 3 piece alloys I have.
So am attempting to fit some 180sx hubs today
Will hopefully post pics soon, but just wondering with upgrading to 4 pots will i need an adapter if I use the 300zx rotors
https://www.sau.com.au/forums/topic/246744-y31-brakes/#findComment-7776388
  • 2 years later...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
