  • Replies 148
My MR2 has just developed a leak in the targa roof so if I don't fix it before tonight (just needs some silicon) I'll have to bring my other car... the commodore VN :thumbsup: Sorry guys :)
Looking forward to it. I'm eating a small lunch now then starving myself until tonight! Gonna get my moneys worth :banana:
Kris, gimme a call later and let me know what time you wanna meet up.
No probs mate
doesnt matter what car you bring to meets / cruises.... we dont really care. The people make a event NOT the cars
AP is just saying that because he wants more people to come so that there is more duckage. He will make you order duck and he steals it off your plate. Be warned
shhhhhhh!!!
hey give me a buzz, before you go to the meet
shhhhhhh!!!
No probs man, I finish work at 9 so ill call u after that, should be there at 9:30 give or take 10 mins. You guys should still be there anyways.
Sif starve yourself
I'm about to have lunch #2
Yeah but dude I weigh like 20kg :) Gotta make room for this duck tonight. It better be as good as I'm expecting!
Oi Kris I'm bringing one of the chicks tonight :) Only met her once when I was drunk though so I can't remember if she's hot or not :P She txted me saying she wants to "get to know me better" tonight so I invited her along.
Yes, I am going to pull an "eMsta" might not be able to make it tonight
u live like 2mins down from the meetup
sif not at least show ur face
rain, hail or shine ill still be there
Yeah dude, you better be there!
You're one of the only people that I actually know. I need someone to talk to when I'm there aside from Kris! :)
If you don't come tonight then I'm not taking you clubbing like I said I would... :)
:P
Edited by jezza boii
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
