crank/cam angle sensor
suit rb20/25/26 r32/33
good condition tested on my car bearings are smooth & quiet
was a spare for my racecar but now have gone with crank trigger system
price $110 plus postage
contact jason on 0424348521 or pm
https://www.sau.com.au/forums/topic/246920-camcrank-angle-sensor/
post it to me for a couple of pineapples and its sold
test that shiny one and let me know via pm how it works out and if it works well ill probably take it off ya hands jase
dont necessarily need it but the rest of my engine bay will be shiny soon so why not..... and it never hurts to have a spare lolz
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
