i was reading in the forced induction section that you can change the 2 stage boost to just run 7 all the time. the guy who did it was having problems but i was wondering if you guys would recommend doing this and if it is hard to do. from what i read you have to cut a wire and then ground it or something.
https://www.sau.com.au/forums/topic/247252-r34-2-stage-boost/
  • Replies 80
Posted Images
It's pretty easy. Essentially, theres a sensor which has a white and a black wire going into it. Cut the black wire and ground it to a nut (closest and easiest one is the Strut bar bolt).
Once thats done, start the car and give it a boot!
Boost spikes??? Some how I don't think so. Its basically a factory setup, its just not running dual stage. I don't see how boost spikes can happen.
Boosting to 15 psi also seems crazy. I mean, the wastegate actuator opens at 7psi. There is nothing in the lines like an EBC or manual boost controller, so the wastegate actuator is doing all the work. Don't know how he possibly boosted to 15psi.
Thats what I was thinking. If u get boost spike after doing this, you would have got it before as well. Nothing will change other then more boost at low RPM. Whoever said that is either speaking shit, or had a massive problem. Or is confused. Either way, they're wrong.
Dooo it Sunny!!!
You can feel the difference when you do this little mod. 2psi may not be much, but hey, its a free 2psi.
R34's run a dual stage boost same as the R33's. They go from 5psi to 7psi. With the mod its a constant 7psi :wave:
Come on guys. Enough questions. Just do it or buy an EBC or an ECU. >_<
It should never have gone this high in the first place.
now consumers will 'settle' for 99 cents a litre thinking it is 'normal'. next time, prices will hit 2dollars a litre. then they will come down to 1.20 and people will be like "OMG SO CHEAP"....
:rofl:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
