Hey guys!
I have a R32 GTS4 with a set of HSD HR coilovers - spring, 15 step damper and height adjustable.
Now, these coilovers came off a GTST - I changed the rear bottom mounting cups to mate the GTR/S4 suspenion set up.
HSD HR spring rates for a 32 GTST are: Front-8 Rear-6
HSD HR spring rates for a 32 GTR (So GTS4 aswel) are: Front-9 Rear-7
Now in mid corner the car would become very unsettled, oversteer very easily, be unpredictable and kinda "skipps" accross the slightest uneven surfaces.
Its really quite scary, because you cant feel oversteer begining to come in, it just slid out of no where.
Now I was talking to a GTR owner during the hill climbs at Bathurst, and he said he had the same problem, swapped the speings at the rear for 5kg's and was cheering.
So, will a 5kg spring sort things out?
Whats a stock rear spring rate for a 32 GTS4?
How do I know how far to dial up the damper settings to make up for th softer spring?
Does it matter if its a 4 door? Weight distribution?
Do i need to check anything on the new springs besides, spring rate, id diameter and length? Would brands matter?
I realise its a bit of a bastardized suspension set up, but hey, it cost me $50 for almost new coilovers.
Could this set up work? HSD HR GTST front coilover:8kg & HSD HR GTST rear coilover with 5kg spring by what ever brand?
Any help is much appreciated
Thanks guys!
Edited by GTS4WD
do you have adjustable sway bars in it? If so soften the rear a touch.
If not, then yes, a softer rear spring will help.
You can also play with more rear toe in.
As far as the adjustable damper goes; you are adjusting both bump and rebound at the same time so you need to find a happy medium. I generally would go somewhere around 10-11 front and rear and pretty much leave it or go up, but not down. I tend to think if you go too soft on the damper thinking that it will soften that end of the car then you aren't controlling the spring properly, particularly higher spring rates, which can lead very similar issues to what you are describing...
Wow.. that acctually makes allot of sence. Because thats exactly what I did! hahaha.
I never really touched the front dampers. I put a front strut bar and GTR bonnet, so I lessened the weight and stiffened it, so im happy with the front. Feels great, direct, no understeer etc. Dampers are set at 0. Should i be increasing them to further change the ratio front/rear?
You have to excuse me. Im not inept in terms of suspension. But im not fluent in its techincalities. Its by far the most difficult part of a car to grasp, understand and disect.
Current specs are:
ride height- front 350mm rear 345mm
alignment- front 1;5 deg neg camber, 5 degree caster, 1mm toe out, rear 1.30 deg neg camber,
2mm toe in per side
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
