As topic says, my RB25 r32 is up for sale.
I have owned the car for just over a year, but have to sell it as I no longer have any parking space for it, due to being set to receive a company car in early Jan.
I purchased it as a rb20 manual and since receiving it have spent over 12k in the past year, with receipts to show.
The RB20 was removed early this year and replaced with a rb25 engine and manual gearbox out of r33 front cut with 115k's on it.
This was done by ECC and the car is fully mod plated and legal.
During that time a major service was done, replacing the belts, waterpump etc, just to be on the safe side.
Since then the car has covered just over 10 000kms.
During the 10000kms, the car was a work in progress, with the following mods/parts being added;
Engine:
RB25det, 128 xxxkms on it
New engine mounts
New belts and waterpump
High flowed turbo, by Precision Turbos
CES split front/dump pipe
High flow cat
Stainless steel catback exhaust
Hybrid Front mount
Apexi Pod
Splitfire Coils
Turbosmart plumback blow off valve
Walbro high flow fuel pump
Malpassi fuel pressure regulator
Computer
Power FC
Gizmo Intelligent Boost Controller
Drivetrain and Suspension
RB25 Gearbox
Cusco single plate clutch
ISC adjustable rear upper arms
ISC adjustable toe arms
GAB coilovers front and rear
Custom one piece 3 inch tailshaft
Hicas lock bar
Zone 17inch by 9 inch wide rims
255s on the back
235s on the front
Also, spare set of r33 standard wheels with 95% rubber
Interior
Splitfire boost and oil pressure gauge
Blitz automatic turbo timer
Cd player
JVC splits in front
Sony Xplod 6by9's in back
Kicker 10 inch sbu
2 channel amp powering JVC splits
2 channel amp powering Kicker sub
Exterior
Trust GRacer copy front bar
M spec side skirts
M spec rear pods
Overall the condition of the car is good. Mechanically it is perfect. Exterior has a few blemishes as expected of a 1990 car. The car was built to be a quick streeter with the goal of ultimately taking it down for circuit racing. Unfortunately, the budget at the moment does not allow for this, and the car has not seen the track, apart from one Willowbank outing, where it made high 13's with stereo components, full tank and myself (110kg). It was my first time down the strip and the car is easily capable of low 13's.
The power fc was installed and tuned by Brisbane Tuning and Turbo Centre and was tuned for reliability, making 219rwkw at only 12psi.
I am asking for $15 000 FIRM.
The price is firm as I can part the car out and recover more money, but do not have the patience.
No swaps please as my work car is arriving in Jan, and there is simply no room for another car at the moment. I may be interested in a swap for a roadbike plus cash.
For any questions, or to arrange an inspection, please contact me on 0408 457 698. Please note, the car will not be available to be picked up until early Jan, when I pick up my work car. Up until then it is my main mode of transport.
https://www.sau.com.au/forums/topic/247309-rb25det-r32-modified/
Hey interested buyers,
  • Went to check this car out today, definitely needs a respray, body is straight, panels in good nick.
  • Motor sounds good but possibly running rich (exhaust is jet-black) , possibly re-tune.
  • Interior is sound, but requires gearbox/handbrake boot. AC window vents good, left hand side vent looked to be on way out.
  • Needs bit of work for a RWC (rear windscreen wiper, speedo, tires etc).
  • Surprisingly stereo not installed, unsure y, due to listed in specs (did see evidence of amp in boot and parcel shelf speakers)
  • Speedo needs hooking in (navara mod) Passenger window needs attn (possibly loose connection or motor / switch) Sunroof doesnt work, possibly come off rails.
  • Owner says there is a clunk in one side of rear coilover (booked in next week)
  • All chassis / vin numbers all match up and are legit however, according to Nissan Fast its 1989. (see image for confirmation)
  • I'd say this is a great car for somone who is willing to spend the time or money to get it up to scratch, otherwise quite a nice car.
Thanks,
Good luck with sale.
Thanks,
for rwc it needs:
speedo to get hooked up - pretty straight forward. have the part number needed, and it's a $30 part
needs the rear wiper to be reattached
needs the hicas warning light to be turned off at the dash - hicas has been removed
and that's it.
the r33 tyres are in rwc condition. they are less than a month old.
will get some engine bay pics up
stereo is working, but is out. used to have a dvd player, but pulled it out. have a pioneer cd player, but haven't put it in yet.
cheers
ps. at the moment am not selling the car in parts, so won't be selling it without wheels etc, as i will have no use for the wheels once the car is sold.
if i do decide to part the car out (ie, it doesn't sell), i will part all the bits out pfc, turbo, exhaust etc etc etc to recover the cash.
  • 4 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
