there you go Redgurl, all the answers you will ever need!
for all that look for the water temp needle to move, dont. it is not the indicator that your car is ready to be driven.
all the engine need is oil to lubricate its moving parts, hence we have the oil pump to do the job which starts the moment we turn the key.
fir those who said that it is a waste of fuel to warm OUR skylines up for a few minutes, please reconsider. what about those moments when your on full boost and chewing up shi t loads of petrol?!! not a waste of fuel at all brother.
I personally would like to call these warming up procedures a "long term investment" instead. after all, warm her up cool her down is the name of the game! simple:)
thats me 2bucks
ron
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-528137
  • Replies 85
i hope u guys realise that idling ur engine for long periods will not help ur engine last longer . have u ever heard of cil bore glazing ?
thets what happens if u idle it for long periods . if u want to sit in the car for 1-2 minutes thats fine but idling for 10 minutes every day its a sure way to glaze the bore .
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-528231
yep, i for got to mention. it is actually not a good idea to let the car idle for a long period of time as wrxhoon said.
i heard that the mixture will lean out. i have actually tried it my self with my A/F mixture guage. it leans out after about 5min after looping for a while. this is bad for your plugs also.
just keep tapping the throttle every min or so and it should be just fine.
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-528236
the engine is not designed to idle , not having any load on , so when its not under load no pressure on the pistons or rings thats why it will glaze . believe me there is no advantage to idle u r engine to warm it up maybe ok for a minute or 2 definatly no more just drive off and take it easy until it warms up . siting there idling it will take a lot longer to warm up as there is no load .the engine is not as eficient when cold cause its designed to run hot the hotter the more efficient it will run thats the reason u have a thermostat so it will warm up quick . if the materials used in the engine could tolerate higher temps they would tun them a lot hotter .
ron if u want to sit there idling u r engine for 10 minutes every time u start it then do it but dont think u r helping it cause u r doing it more harm than good . its like some people when they run their engines in they think that they should drive under 80 kmh and very low rpm all the time . thats wrong too the rings will vever bed in promply like that .
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-528250
glazing the bore happens when engine rpm remains constant for long periods of time, idling for example...
what happens is that the cylinder bore will wear out or get polished(hence the term glazed) between the distance the piston is travelling for long periods at a rev range up and down the bore. Due to the wear by glazing, above and below this distance the bore will be smaller making a shoulder, and when revs increase, the piston travel will also increase, the shoulder on the bore will destroy the piston rings prematurely...
this is especially common when running in re-co engines ...thats why you shouldnt drive at constant speed/rev with a reco engine until you have done a few hundred k's...and never idle for long periods....
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-528289
Another bad thing about letting a car warm up idling for too long is that the engine is running rich and thus you get more bore wash.. and hence more wear in the bore and piston rings. Also you want the operating temp to be reached as quickly as possible (in a gentle manner) to get any condensation outta the oil and CC, which produces acids which attack metal. An engine takes 3x as long to warm up to operating temp idling than it does gently driven. FWIW I let my car idle for 30 sec and then drive off....
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-528333
Originally posted by RedLineGTR
WazR32GTSt how do u run your car from a cold start??
i turn the ignition, go back into the house and get my bag and some sort of breakfast bar to eat in the car, then go
that gives me about 2-4 mins of idiling before i get into drive and the engine is happy as larry!
well sumamrised demon dave... can i stress the don't drive straight off after starting part! and from what i have read it makes perfect sense not to idle for 10min (that period of time is bloody stupid anyway!)
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-529446
Guest RedLineGTR
Originally posted by Demon Dave
So, to summize then:
It isn't recommended to move off straight after starting the engine from cold, nor is it a good idea to leave the car idling for long periods of time.
guess we have to preheat the engine oil then fill it and then turn the car on...we cant move off straight after starting the engine from cold, nor is it a good idea to leave the car idling for long periods of time..so i guess there would be a fine line...maybe 2min or something...and then drive slowly
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-529458
ok ok... guys... maybe saying 10mins was what made the arguments here... i agreee... everyone should not idle for too long... and should not start off and drive off.... :(
once again... thanks for the lovely advice.
reason i wanted to ask about warming up was because it is such a trivia thing but often over looked... and we should always keep up with the maintence of performance cars anyways.
happy driving.
love, redgurl
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-532062
i was letting mine warm up for 10mins, then was going easy for about another 1mins to let the engine and gearbox and everything warm, with the gearbox you can feel the curnchiness and then after time it gets nice and smooth
but now i think ill only give it 5mins and then take it easy
but then again i have remote start so starting it is easy :D
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-532364
See this just prove that you learn something new everyday.. hehe
I always let my car warm up before driving off. Like 10 mins, when the temp start rising. Now I know not to.
But I feel that the car doesn't drive as good or as smooth on idle if I don't let it warm up completely?!
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-537149
this is an old argument.most wear is one when cold.also the fuel washing the bores ect.sitting with cold engine running must be worse than driving easy.
mine is very slow to warm in winter[well above 0cel],I often have the radiator air flow partialy blocked off.so I can understand the problems in cold areas.10-15 km before overdrive is allowed to shift.
I looked at block warmers and pumps,if any one knows of a good one well under AU$400 I like to know about it.
Thought about a jug element and a pump [off merc,bmw,vw or vectra].
add saftey switches so one dont fry.
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-537190
davehoos 10 - 15 k before it reaches normal temp ? is that the coolant temp u r talking about ? thats to long if u r thermostat is working nornal it should take no more than 3 - 5 k .
as far as going to overdrive ( auto ) it depends how fast u r going if u reach say 80 kmh it should shift it doesnt matter how cold it is .
change the oil in the trany , it may fix that . as for block warmers we dont need them here , not cold enough to worry about .
https://www.sau.com.au/forums/topic/24741-warming-up/page/2/#findComment-537537
    • Talk to hot girls via live cam. Adult dating made easy and exciting. https://secrelocal.com private ladies for discreet encounters
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
