  • Replies 112
Are there a lot of imports? Not only for the drifting?
If your number plates indicate a negativity towards V8's, would it be wise to go?
There is a cubic shitload of imports at PC events and there is NONE of the attitude you get at Summernats. None!!
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298908
except when you happen to make the final of the street racing.....then disqualify you...please post vid.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298911
That's nothing to do with the import sentiment. It just doesn't exist at this event.
And just in case someone brings up the autostyle issue, Dom was beaten fair and square by a faster car and would have been time and time again.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298971
what about me....post the vid....post the vid.
im only coming back to P17 to get whats truely mine.
what about me being booed by the punters every time i knocked a knuckledragger out of the competition.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4298983
It wasn't just the knuckledraggers booing. But it seems you couldn't hear me behind the camera! :) :)
:D
Oh, you're gonna have to get around me to claim your trophy dude.
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4299010
It wasn't just the knuckledraggers booing. But it seems you couldn't hear me behind the camera! :):)
:D
dont have to get around you as the last time we went heads up it was disgustingly one sided....lol
where's that vid?
you will have to put it on the back wheels to get me.
the smack talk has officially begun. :)
https://www.sau.com.au/forums/topic/247414-powercruise-17/#findComment-4299080
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
