On the look out for a new engine.
my old stock block spun a bearing, althou i managed 10.97s and 212km/h(133mph)
good stuff in those std rb26´s=)
so im planning on running a 8-900hp engine next summer
maybe someone has a forged or stroked engine or such that the want to sell?
complete engine or just bottomend
/michael
https://www.sau.com.au/forums/topic/247470-wtb-rb26-forged-or-rb30/
/michael
iv got rb30 bottomend with eagle rods and cp pistons,how much you wanting to spend
if im having an rb30 its got to be prepped for a gtr 4wd.
otherwise ill buy a "new" 4wd bottomend prepped from rips or something like that.
im willing to spend some cash if its the right engine.
so write down the spec and your asking price and we will go from there.
/michael
/michael
as far as i know it is right i was doin a 25/30 so there shouldnt be any problems with using the 26 i could well be wrong tho
dont know if the rb25 has the same bolt pattern as the rb26 head,never looked at a rb25 so thats more than i know hehe
guess you dont have a custom sump for 4wd application to go with the bottom end?=)
Hi Mike,
Also on the SAU forum :D
I have the following engine available (still in parts so can be build up to spec):
Block:
- HKS pistons
- H beam rods
- STD balanced, polished crank
- N1 oil pump
- N1 waterpump
- Power Enterprise timing belt
- OEM idler, tensioner
- ACL rod+ main bearings
Head:
- Rebuild STD RB26 head with bronze valve guides
- HKS 264 cams with Trust valve springs
- Tomei headgasket
price 4750,- euro shipped
The whole speclist can be changed to your needs. Also porting and other possibilities.
Let me know if this suits you.
Jonne
Edited by Sky-Engineering
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
