Hello all,
I am selling a gtr32 89 COMPLETE.
body:
full custom spray in Pearl White
n1 side skirts
bonnet lip
boot lip.
Not a lot of work needed to get it back to mint.
interior:
standard interior in a1 condition
blitz boost controller
defi link controller
mines 360 speedo
razo gear knob
Alpine head unit
wheels & brakes&suspension:
17 inch 3 piece race wheels
cross drilled discs
Ohlins adjustable suspension.
engine
stock(Not working)
Piston 6 damaged.
Pod filters
Z32 afm's
TRUST drag intercooler
Custom exhaust.
Kings steering wheel.
bathurst group a Turbo's.
(Not sure of the spec).
Custom intake
I have tried to give the best description, asking $9500 for the complete car.
Gear box,diff, all other parts ie brakes clutch etc are in working order.
Photo's attached
NO tyre kickers or parts buyers.
Interested in selling it whole........
PM Me if you are interested.
https://www.sau.com.au/forums/topic/248196-complete-r32-gtr-89/
  • 3 weeks later...
how is the engine not working???
does it not turn over??? blow smoke??? does it run but like crap etc???
am imterested maybe in a swap with cash my way.
Blew out the dip stick.
After testing compression Piston 6 is damaged.
ouch. i know the feeling for that. not good.
gl with the sale. if i had the cash and not my car id come and get it yesterday.
  • 3 weeks later...
How has someone not taken this yet!!! Great deal considering you can rebuild the engine have a nice GTR with 0kms on the engine for probs 15k.
i dont know but if i had the money it would already be here with the motor out.
still not up for a swap???
Thanks for the support gents.
So true...I am just adding the parts ..rolling shell,bonnet,panels,wheels,suspension etc etc...all adds ups..lol
PRICE DROP $8500.
If I don't sell it...may have to re-build the motor and keep it...cause it is after all a R32 GTR.
Anyone want to see it..call me 0416176058
I can supply used R33 Crank(bent) rods and pistons cheap($500) if some one is interested in re-building it.
14K now..lol
Looks nice, it's a shame it's a little over my price range, else I would've bought it and slapped my engine into this one instead!
Good luck with the sale and free bump.
OK...An update for everyone.
The car is at the work shop to asses the damage.
Please call me if you want to inspect it on site........I will need to arrange a convenient time with my mechanics.
Cheers
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
