Hey all,
I am having some problems with 4WD in my R32 GTR, I have searched and read every other post but all other probs seem different to mine.
Basically I am getting no 4WD light on, no error code leds, have checked fluid level etc. etc. I am thinking that my attessa computer is fried (had an alternator power surge few weeks ago) but I was wondering if someone can let me know how to test this before I go and buy another one. It is going to an Auto elec on Thurs and he also hasnt had any experience fixing this so some steps in the right direction would be great!
Cheers,
Mitch.
https://www.sau.com.au/forums/topic/248217-4wd-attessa/
The AWD light is a warning light, signalling that there is a problem with the ATTESSA system. If you don't get the light on (other than when you initially switch to IGN), then there is nothing wrong with ATTESSA.
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4307440
First thing to ascertain- does your 4wd light come on when you turn the key to ignition? If not the bulb is blown. Do you get a gauge reading for the AWD under acceleration?
Thanks for replys :(
No it doesnt, so the bulb must be blown. And no gauge reading, car is definately running 100% RWD...
When my alternator surged it blew lots of other things in the car (including globes in the dash, so its probly blown 4WD one then aswell, also relays, headunit, fuses (since been replaced) etc.), and it is since this time my car is only running RWD. Given my alternator has blown so much stuff up I was thinking it may have done the attessa computer too.
Would there be anything else electrical I should get Auto elec to check and is there a way anyone could point out to test this computer before buying a new one.
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4307786
i would have thought that there would be a protecting fuse that blows before the et-s computer would be damaged. Got the wiring chart (in 2 parts ) for the et-s system for what it's worth. Can you try another known working computer?
Picture_clipping_2.zip
Picture_clipping.zip
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4308963
Couple more trouble shooting pages that might help you out, don't forget to check the fuse for the attessa pump too.
Picture_clipping_3.zip
Picture_clipping_4.zip
Picture_clipping_5.zip
Picture_clipping_6.zip
Edited by doo doo
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4308981
ABS
Just force the brkes to lock up, see if the ABS does its job.
ABS has been taken out.
Yea I dont know how surge got past fuses but almost all of them were blown and it blew headunit etc. which is on a fuse, so im not sure how that happens???
Anyways thanks again for suggestions and thanks doo doo for links, ill check em out now :)
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4308991
Hmm pics dont work doo doo, looks like they are in some mac format...
Yeh bugger, they are and they need to be unzipped and downloaded. (know someone with a mac?) They basically do the whole troubleshooting thing so get a download of the manual from somewhere online and check it out- I reckon you'll save yourself a fair bit of grief.
Edited by doo doo
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4309476
Nah dont know anyone with a mac... I do have a R32 workshop manual and have found the pages relating to the attessa system, ill check these and get them to the auto elec to see if he can do anything with em..
Thanks for you help anyways mate!
https://www.sau.com.au/forums/topic/248217-4wd-attessa/#findComment-4311447
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
