I have had some really good result with steel wheeled stockers....
-7's seem to be the turbos of choice here though.
Here is my 2c (I'm not a mechanic or a tuner - so.... its free...)
- combined with some good tuning and cam gears 300kw is not out of the question with steel wheeled stockers
- ball bearing turbos are overated
- the .48 Exhaust housings on the stock turbos make for brilliant response
- on a stock engine (particularly one of unknown history) - steel wheel stockers are capable of bringing it to its limit of reliability / power without sacrificing response.
- to my understanding - when it comes to servicing - rebuilding stock turbos is much cheaper / more cost effective than overhauling Ball baring varients (such as -7's)
I have even seen some GTR's running -7's with a 0.48 rear housing (they usually come with a .64) in order to make them into a nicer - more responsive turbo - have seen a safe 300kw on this arrangement too.... Stock turbos allready have this housing.
I have also heard (and believe only half the things you hear...) of a reputable melbourne workshop making 360kw using the comp side of the factory turbos (with an "undisclosed" exhaust turbine configuration).
Anyway - just some opinions / "insight" to throw into the mix.
Have Fun!
thats a good start
cheers
Edited by Antimatter
I have stockies with steel wheels, done by slide of these forums. Response is very nice not sure about power yet as haven't upped the boost yet. If going this way though I would suggest changing the actuators to something new as they are old now and now I have problems with them....
The best response we saw on the dyno so far was with the actuators unplugged we saw 13psi by 2.5k but had to back off so to not overboost them (troubleshooting slow boost build issue)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
