Age: 12 y.o
Condition: All parts are in working order
Contact: PM with any questions
Comments: I need this stuff gone, im letting it go for cheap.
R33 GTS-T Series 1.5 Differential Cradle w/ Diff & Hicas Rack (ABS) - $200
R33 GTS-T Series 1.5 Front Upper Control Arms - $50
R33 GTS-T Series 1.5 Front Castor Rods - $50
R33 GTS-T Series 1.5 Front Wishbones - $50
R33 GTS-T Series 1.5 Front Brake Hubs w/ Lines - $100
R33 GTS-T Series 1.5 Front Struts w/ Springs - $100
R33 GTS-T Series 1 Inlet Manifold w/ Throttle Body - $50
R33 GTS-T Series 1 Ohlins Rear Struts w/ Dampening Adjustments & Springs - $100
Pictures can be found at:
http://www.skylinesaustralia.com/forums/R3...ts-t238267.html
https://www.sau.com.au/forums/topic/248578-fs-r33-gts-t-parts/
Following items are free :D , pick up only....
Series 1.5 ABS Unit
Series 1.5 Window Washer Bottle x 2
Series 1.5 Overflow Bottle
Series 1.5 Brake Booster
Series 1.5 Clutch Master Cylinder
Series 1.5 Passenger Side Power Window Switch
Series 1.5 Front Windscreen Wiper Motor
Series 1.5 Rear Windscreen Wiper Motor
Series 1.5 Rear Brake Caliper (Side Unknown)
Series 1.5 Rear Brake Rotors
Series 1.5 Pedal Assembly (Clutch, Brake & Accelerator w/ Throttle Cable)
Series 1 Turbo Heat Shield
Series 1 Rear Spoiler
If you want any of these please PM me or SMS me on 0413 351 827
Thanks
  • 3 weeks later...
DaGr81 - yeah mate just give me a call in the morning and we can arrange something
i leave home around 4pm to go to work thats all
**R33 GTS-T Series 1.5 Differential Cradle w/ Diff & Hicas Rack (ABS) - Sold
Only the sub frame remaining - $50ono
Series 1.5 ABS Unit
Thanks
Hi I was wondering would you have the front bumper bar.
Thanks
sorry man i woke up a bit late i work in the city monday - thursday and can pick up after 6pm any of those days, other wise friday afternoon after 2pm, let me know which is best, once again sorry :happy:
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
