Hey guys,
The PGA-SA Interclub Dyno Day is on once again! Topic from previous day can be found here:-
http://www.skylinesaustralia.com/forums/Pg...ay-t225222.html
Just trying to get the word out to all the clubs. Last 2 days were a reasonable success, and a number of you bloke rocked up last year to show off some pretty tidy machines, and put out some pretty impressive numbers, which was awesome to see! The turn outs have been pretty good, but this year we want to make it huge! We had and do have a number of sponsors for the event, and hence prizes & awards on the day. There is also talk of a 50 entrant extended day, and a show & shine on the primary school oval adjacent GWW, but confirmation is yet to come.
Link to official webpage, is below:
http://www.dynoday.info/
Link to thread on our site, is below:
http://forum.pulsar.org.au/showthread.php?...454#post1549454
Hope to see some more of you guys attending or entering once again!!
Cheers,
Rick.
  • Replies 305
Yeah.. it was actually posted up, and in full swing back in october. I've just been a bit lazy with promoting, and I thought it had already been done here on SAU by another member of the PGA club. He had posted up about it, like 3 days after the last one was over.. :D
The reasoning for that was because he had planned ot have it earlier in the year on a permanent basis, starting by kicking right off with next year to begin with! The only thing is, because this one ended up so late in the year, and because the next is ending up so early in the year, they have become real close together.. :P
But don't be fooled... we promise a fantastic day will ensue! :)
Rick.
  • 4 weeks later...
so is there any more updates on this
i went down to graham west workshops last week to get some work done
and enquired about this
they confirmed it but dont know when they will start taking payments
more infor please
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
