Hi guys,
im striping my R32 GTS 4dr in prep to build it as a race car.
so ill be getting rid of a few things
ill disscuss price with buyers
main items
front bumber that has fog lights in the bumper not the head lights
16" amg multi spoke rims
2.5" jap brand exhasut
bonnet
m-spec front seats
all interior
call or txt me on 0411895116 as im not on line much
https://www.sau.com.au/forums/topic/248779-r32-gts-4dr-parts-to-go/
Hi guys,
main items
bonnet
m-spec front seats
all interior
hey mate, how much for centre and passenger side air vents in dash?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
