hi guys how yous going, went for a drive to the city lasat night and yes it ws pissing rain and i got the carbon fibre bonnet with the vents in it, as we were coming back to the area my car just stalled and we tried starting it several tyimes and it wouldnt kick over, i just got the car tuned down at racepace last week with a sard 280 pump whih i bought of a forum member on sau and it was second hand also, also the nismo 555cc injectors and a niusmo fpr, now what i think the problem is it could be the fuel pump, it starts like 10mins later but then it drives for about 2mins and then switches off, its really weird, the previous owner of the sard 280 said it hasnt even done 200km on the pump, well all the blokes that were with us said it could be the fuel pump because i dont think it has anything to do with the injectors as ben from racepace would of told me, the car is a at a mates house as we had to push it for like 2kms in the pooring rain but just want to knwo what it could be so any help or advice to check anything will be good guys and what i also thought it could be was i have a vent right where my z32 afms are and a little bit of water got to them but i didnt see that could be the problem as the car should just konk out like that if it had anything to do with the afms the car would just be idling funny i would think but yer this is the first time it happened and it was also in the rain, car never comes out in the rain but had to drop someone off and just went out from there instead of going back
the car just wants to start but just isnt kicking over, i wonder what it could be, can it be injectors or will it be the fuel pump?
thanks heaps guys
cheers tony
https://www.sau.com.au/forums/topic/248812-my-gtr-just-konked-out-last-night/
  • Replies 45
Posted Images
Hey bro.
dont think itl be the injectors. Could be the AFM is all clogged up. Have you tried cleaning it with some brake/electrical cleaner?
Another thing, can you HEAR the fuel pump prime when you turn the ignition? When it does start up, can you drive it/rev cleanly? No misfire?
disconnect the CAS then remove fuel hose from inlet to your FPR and see if there is fuel being pumped out. My guess is your FPR has come loose and wound itself out and cut off fuel.
Also your car will run without AFM run like crap but it will run so i dont think it could be those for your starting problem, would be for higher in rev range but not starting.
yer i dont think it will be the afms aswell, tacker ill do what you told me and ill see how we go mate, like if we tried starting every 10mins it would start but then will just switch off again, this is like my 1st problem in almost 3yrs grrr
Is it just me, or are you guys missing the REAL basics?
You have a vented bonnet, it was pissing down rain.
You've filled something electrical in the engine bay, most likely your coil packs, with water and they've stopped working.
You're going to have to disconnect everything electrical and spray CO contact cleaner in there, then put it all back together.
Bitch of a job, but it's the only way, unless you wait about 10 days for the water to evaporate.
hrmm you could be right but the car has beeen out in the rain before and nothing happened then, so what should i be taking off you think bro
I'd be mainly looking around the coil packs.
Pull the coil pack cover off, and see if any water is sitting down under there.
It may have been in the rain before, but depending on how hard it's raining, the motor may have been hot enough, with not enough water coming in previously to cause issues, as it'd just boil the water off.
The other night, may have just been way too much water, and it's flooded the top of the motor.
But I'd be mainly looking at the coil packs, and their connections.
Hey mate, i had the same problem with my SARD pump, u need to make a better earth terminal for it, there is a white wire the goes into the pump, its the earth for the incab noise reduction feature thing. tap in another earth line and it wont affect it again,,
Just needs to be earthed correctly,
its very easy mate, you dont need your mechnic to do it. its one simple wire to hook up..
In your boot where the wires for the fuel pump are located..
There are two plugs that hook up to your pump and computer n other things, like the incomfort feature for the standard pump, basicly restricting voltage so its not constantly running,
Anyway take the lid off, four screws.
Then take the plug off to the left hand side,
Then there is two wires, on that plug, yellow and a black with a lil bit of yellow on it..
tap a line into the YELLOW ONE, (new wire) then make it long enough to earth it out, tape it up and your good to go..
It will never fail again. and it will start and run every time. I think it must just be a common fault with 32GTRs the sard pumps, becuase a mate of mine also had the same issue,
try it mate and tell me how you went..
Edited by foney
wont be the coilpacks.
my cars got a vented bonnet and was out in the rain for a while, water got into the coil packs, car still started etc, but ran like a dog. 2 coils weremt firing cause they were swimming in water.
So his can't be an issue because maybe 6 coils are now swimming in water?
Do people around here not have common sense?
What you've just said is:
I had my car in the same condition, and it can't be what you've said, because I had happen what you said, just not quite so severe...
Smart...
Smart...
bloke there was no water nowhere but around the afms area mate, the car is strating pretty sweet this morning but im going to do what foney said and i think it will fix the problem, will let yous all know how it is
cheers tony
Smart...
Haha oh man, that is gold i was thinking the same thing
Simple test, switch the ignition on, do you hear the fuel pump prime? Yes? Unlikely to be a problem with the pump.
No? If the battery's ok then you might want to have a look at the fuel pump, is power getting to it?
You can try directly wiring positive/negative from the battery to the fuel cell thing (the part the wires in the boot plug into which go to the pump, be careful) will let you test if its working.
However, I do agree that its a good chance you may have water on your coil packs...(note fuel pump will also stall the car, but there's more than one cause).
Foney, in regard to the fuel pump not been grounded, I had the same issue, car just wouldn't start one day and fuel pump had to be re-ground, not sure if its a stock fuel pump or not but it was ok for about a year (R33 GTR) and it just died a week ago...(fixed now).
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
