Ok, The long and the short of this little tale is that the head I have has a bit of a bow in it..
My machinest can straighten this, and re-cut the valves and all that other stuff,
But the question that I really need to know the answer to is how much can I safely shave off the face after all the other work is done?
its a stock RB30 bottem end, stock 25det head. Stock head gasget, stock valves, stock cams (Planning on pon cams during the year!)
I would like to raise the compression if possable, can you guys help?
https://www.sau.com.au/forums/topic/248892-head-surfacing-for-2530/
Your best bet is too get another head.
As to straighten a warped aluminium head PROPERLY will cost you more or nearly as much as to buy another. The process involves heating the head to the point where it straightens itself, or levels itself out so to speak. This in itself isnt the expensive part. You will then require to have the camsaft tunnels line bored to make sure they are straight, and more than likely the majority of valve seats replaced ( new ones pressed in ) , as they come loose due to the different expansion rates between the two different materials.
If your machinist just plans to surface it - then you consider all your optins first.
yea , I am aware of all you said. They sometimes 'pull' the lifter bores out of round and valve guides can fall out as well!
All of which I am aware of.. thanks for the heads up. Yes, he is doing all that plus a cc check, pressure check and crack test before any machining takes place..
The old owner must have had an issue, cos the deck face is flat as, but the cam journals are a bit out. We are thinking that the old engine had an issue and he just skimmed the head and away he went without checking anything else..
So the question still remains, after i get all the other stuff fixed, how much can be shaved off the face? has somebody done a valve to piston check? does someone know the answer I am after?
if it was me, i would just get one of those engine CR calulators on the net and spend an hour punching in numbers, until you get a combo that comes up with a good CR, somewhere around the 8.2-9.0 mark.
When you say stock bottom end, std pistons/rods or rebuilt? stock 86mm bore?
I'm not sure what the stock hg thickness is, but you'll need to work that out, im sure someone here will tell you.
I would just take off as little as possible from the head, just untill its level, then definately cc the head so you know how much to take off the block to get your target CR. You have much more to work with, with the block since the stock pistons sit below the top of the bore, so if any decent shaving is to be done i would be looking there, not the head.
So basically, if you want to keep this head, get it sorted with the lest possible taken off, find out how many cc's there are in each chamber, determine the hg thickness, then get on the calculator and work out how much you need to deck the block to get you CR, you might even zero deck the block..
the block has completly stock everything atm (226 000km on it! not going to refresh it), going to just run it to see how well it goes, if it works as well as I hope, I will start on 'built' engine. But this mongrel head is being a pain in the butt. If its not sorted in a few weeks I will buy another head and go nuts on it!
Thanks for the input. Got any links to a compression calculator? cheers
google.com.au :banana:
or spoolup, the person that answered in this thread has one on his website which is in his signature.
By the sounds of things, if the head has been that badly warped it would be cheaper and easier to just get another head. Goodluck with it
Edited by R34GTFOUR
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
