HALP HALP!!
i got GT5 yesterday
finished C class. and saved and bought an R35 GTR
but the question is.
how come it keeps sliding? and secondly. can you do up the cars like in GT4?
i'de love to add some new rims to my suzuki cuppacino :(
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/
can't change wheels;
if i remember right once you get to A class or something you can start tuning the car (just increase the power, decreasing the weight, changing suspension setup and changing gear ratio)
can't answer the question about the R35 GTR maybe its just your driving style
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4319602
hey i've got it, once you complete all of the races C - A class, you can then tune, but that is about all, keep in mind its only the Prologue (i believe its only half of whats in the full game)
I havent played in a few weeks, but when taking a corner, you need to keep on the accelerator, even just slightly, if not youll begin to lose traction and bang!
so ideally, slow down heaps as you get to the start of the corner and power through it.
hope this helps
Steve
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4319865
THANKS STEVE!
but it seems to just power down when i accelerate while turning..
id'e hate to say, but the EVO drove nicer than the GTR. just a great lil car to drive.
the GTR is good fun tho, sliding around the corners.
i got the physics thing set to pro because im just that good :( but all the friggin GTR's keep hitting me and penalising me in the GTR race at the dealers
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4319901
ffs cant get past the integra race where u gotta pass everyone in class B
lol its pretty tough, but it is possible,
don't worry about hitting other cars, just go hard, use them as bumpers around corners if necessary, i dont think you get penalised for it, so go hard!
https://www.sau.com.au/forums/topic/248965-gt5-p-halp/#findComment-4324291
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
