Hi guys, im wrecking a 1992 R33 s1 5 speed gtst.
car has damage to the front and rear passengers quarters from someone doing a U turn infront of the previous owner
so the car is complete minus front passengers side guard and headlight, bonnet, front bar and stock intercooler
Its stock apart front having a turbo timer, 3 inch straight through cat back exhaust, 17s and lowered springs
its currently running and driving fine (had to do some funky intake piping to delete the non existant cooler), so for anyone interested in the engine or box it can be test driven
Engine has 110,000 Ks one it and has only ever seen stock boost
Gearbox was rebuilt just before the previous owner got the car and he had reciepts for it, but unfortunately didnt keep them. so the box has had around 6 months of driving on it since it was rebuilt
would like around $3200 for engine and box with all accessories and stuff to pretty much make the engine run, im negotiable on the price and whats included with it
Brakes and 5 stud stuff
Front and Rear calipers with pads and lines
front and rear rotors, measuring 29mm thick front 17mm thick rear
all drum handbrake stuff with cables
front and rear hubs
bm44 non abs master cylinder
all in good working order
$1200
wheels are WEDS brand 17x8 front and 17x9 rear with +38 offset all round. front tyres are 235 45 17s and about 80-90% tread rears are 255 40 17 and are about 90%. and the front rims are 4/5 multi stud
would ideally like to sell engine and box before i sell anything that will stop the car being driveable just incase someone really wants a test drive
Located just outside of geelong, vic
happy to post anything that australia post will take
PM or reply here with what you want or if you want more pics or anything
cheers
Nick
will get more pics of the interior and stuff tomorrow if i can find the camera
https://www.sau.com.au/forums/topic/248999-wrecking-s1-r33-gtst-5-speed-vic/
  • Replies 64
hav you sold all the plastics from the gear surround up to the top of dash? (around climate control etc)
nope, all of that is still there. was supposed to sell the gearstick surround with the full manual conversion but havnt heard back from the guy that was interested
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
