Hi guys, im wrecking a 1992 R33 s1 5 speed gtst.
car has damage to the front and rear passengers quarters from someone doing a U turn infront of the previous owner
so the car is complete minus front passengers side guard and headlight, bonnet, front bar and stock intercooler
Its stock apart front having a turbo timer, 3 inch straight through cat back exhaust, 17s and lowered springs
its currently running and driving fine (had to do some funky intake piping to delete the non existant cooler), so for anyone interested in the engine or box it can be test driven
Engine has 110,000 Ks one it and has only ever seen stock boost
Gearbox was rebuilt just before the previous owner got the car and he had reciepts for it, but unfortunately didnt keep them. so the box has had around 6 months of driving on it since it was rebuilt
would like around $3200 for engine and box with all accessories and stuff to pretty much make the engine run, im negotiable on the price and whats included with it
Brakes and 5 stud stuff
Front and Rear calipers with pads and lines
front and rear rotors, measuring 29mm thick front 17mm thick rear
all drum handbrake stuff with cables
front and rear hubs
bm44 non abs master cylinder
all in good working order
$1200
wheels are WEDS brand 17x8 front and 17x9 rear with +38 offset all round. front tyres are 235 45 17s and about 80-90% tread rears are 255 40 17 and are about 90%. and the front rims are 4/5 multi stud
would ideally like to sell engine and box before i sell anything that will stop the car being driveable just incase someone really wants a test drive
Located just outside of geelong, vic
happy to post anything that australia post will take
PM or reply here with what you want or if you want more pics or anything
cheers
Nick
will get more pics of the interior and stuff tomorrow if i can find the camera
https://www.sau.com.au/forums/topic/248999-wrecking-s1-r33-gtst-5-speed-vic/
  • Replies 64
hav you sold all the plastics from the gear surround up to the top of dash? (around climate control etc)
nope, all of that is still there. was supposed to sell the gearstick surround with the full manual conversion but havnt heard back from the guy that was interested
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
