Hi guys, im wrecking a 1992 R33 s1 5 speed gtst.
car has damage to the front and rear passengers quarters from someone doing a U turn infront of the previous owner
so the car is complete minus front passengers side guard and headlight, bonnet, front bar and stock intercooler
Its stock apart front having a turbo timer, 3 inch straight through cat back exhaust, 17s and lowered springs
its currently running and driving fine (had to do some funky intake piping to delete the non existant cooler), so for anyone interested in the engine or box it can be test driven
Engine has 110,000 Ks one it and has only ever seen stock boost
Gearbox was rebuilt just before the previous owner got the car and he had reciepts for it, but unfortunately didnt keep them. so the box has had around 6 months of driving on it since it was rebuilt
would like around $3200 for engine and box with all accessories and stuff to pretty much make the engine run, im negotiable on the price and whats included with it
Brakes and 5 stud stuff
Front and Rear calipers with pads and lines
front and rear rotors, measuring 29mm thick front 17mm thick rear
all drum handbrake stuff with cables
front and rear hubs
bm44 non abs master cylinder
all in good working order
$1200
wheels are WEDS brand 17x8 front and 17x9 rear with +38 offset all round. front tyres are 235 45 17s and about 80-90% tread rears are 255 40 17 and are about 90%. and the front rims are 4/5 multi stud
would ideally like to sell engine and box before i sell anything that will stop the car being driveable just incase someone really wants a test drive
Located just outside of geelong, vic
happy to post anything that australia post will take
PM or reply here with what you want or if you want more pics or anything
cheers
Nick
will get more pics of the interior and stuff tomorrow if i can find the camera
https://www.sau.com.au/forums/topic/248999-wrecking-s1-r33-gtst-5-speed-vic/
  • Replies 64
hav you sold all the plastics from the gear surround up to the top of dash? (around climate control etc)
nope, all of that is still there. was supposed to sell the gearstick surround with the full manual conversion but havnt heard back from the guy that was interested
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
