just picked up my vi-pec plug in board and a boost controller solenoid.
if you go with the vi-pec solenoids you'll need to get some 1/8th BSP hose end fittings from somewhere like autobarn or auto-pro etc.
what i noticed was the solenoids looked very similiar to my profec b spec 2 solenoids, i asked scott from insight motorsports about this and he said that you could use a profec solenoid as it is pretty much the same thing, you just need to cut the loom off and wire it in.
  • Replies 155
Id be interested to see whether anyone has bothered to run the boost controller that comes with these computers. The guy whos retuning my car was part of the development team of these new ecu's and said they are incredibly good.
Wouldnt mind hearing some other opinions as naturally he is a tad bias!
Cheers
i am running the boost controller built into the board through the stock GTR solenoid and it works perfectly
well at least it was til i blew big end bearing and pulled car off road to rebuild
Ray seems to think its possible so I'm going with the stock GTR solenoid.
Taken from the help file with the vipec software.
The number and spacing of the cells in the Table is completely user adjustable. Rows/columns may be inserted or removed where desired by right clicking in the desired place on the labels of the RPM Axis or Load Axis (ie right click on the RPM values to insert a new RPM column). This flexibility allows fine spacing in areas where high resolution/accuracy is required and coarse spacing in less critical areas. The maximum number of RPM columns is 22, while the maximum number of Load rows is 20. When adding a new row or column, the new row/columns cell values will be interpolated between the values in the rows/columns which it was inserted between.
440 maximum load points in each map
And Autronic has 18load, 32rpm. Does that sound correct?
So 576 to 440 points
Yep, but you must have a LOT of time on your hands if you intend to try and tune all of those cells...
The interpolation works very well on both ECU's so you dont need anywhere near that amount of cells in reality if you're only using a revlimit around the 8000rpm region.
I own both an Autronic SM4 and a Vipec V88 and I'm not using the full resolution on either ECU.
Edited by CHA54
Roger that, I agree. I guess for an engine running to 15,000 rpm the extra points may be more useful.
The reason I ask is I was very close to purchasing an SM4 @ $2100(trade price) but really like the idea of a plugin ecu, especially in the std casing. As far a I can tell, all I need is a knock amp to gain all the features I could possiblely need for my motor.
Is there any other functions apart from increased resolution that the autronic has over the Vi-Pec? or visa versa?
Is the cost of the RB26 plugin $1650? or more expensive since it has a built-in MAP sensor?
I am the same, i have a autronic in another car and its awesome, i want to try the vipec but i HATE being burnt by new products, seem to stick with the known good now.
but it seems good and im getting OVER pfc missfire.
Edited by GTR1993
Just went up...they are now $1760 inc gst.
yeah but its nice to condense the resolution near peak boost torque areas or where fast increase in boost and rpm occur to get a nice fuel and ign curve etc. Nothing worse than having big steps and relying on interpolation on big hp cars.
Had a tubbed pro street car making 700rwhp in last week with a "?????" ecu and the resolution was a real issue.... lazy high nine 1/4's on street rubber but i know it could make more power, run quicker, be more driveable (as its a pro street car) and use far less fuel with a different ecu.
Edited by URAS
Just got a quote yesturday for $1663 inc +$20 to upgrade to a 5bars MAP and $280 for a knock amp
must be old stock as all new stock ordered after the 1/2/09 is under the new pricing.
grab it while its cheap!
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
