  • Replies 155
Yes, you can use the wiring for the stock boost solenoid. Mine has been wired up with spade connectors straight into the stock boost solenoid plug :(
You will need to change the way the tubes to the mac valve are set up, though.
well ive only got to choose from 1 black and 1 white wire to connect the wires from the MAC valve (which both wires are black). i dont know which one to connect to which. the wiring diagram only had the colours that come from the ecu which are LG and L/W.
and i still dont know which wires from the mac valve are + and -
I just went and had a look at mine for you. Both wires on the Mac valve are black, but it looks like one has writing on it. I also saw '---', so I guess that one is the negative. The stock BC connector is a rectangle shape with the connectors in a T sort of layout. The connector that is at one end of the rectangle connector is the negative. The one that runs down the centre of the 'rectangle' is the positive. I hope that makes sense.
OK, well there ya go then. That would explain why the wires are both black :D
yeah it confused me at first.. just like injectors.. they don't have + or -
you learn something every day ;) .. dunno what i have learnt yet though :)
yeah it confused me at first.. just injectors.. they don't have + or -
you learn something every day :D .. dunno what i have learnt yet though ;)
Yes you have...
That DiRT is a tightass and wont spend coin on a wideband
Yes you have...
If i am tuning it then you are going to have to have a wideband sensor. Simple.
Anthony, get him to pull the one out of your car, then he can put it back when your done?
No.
I win. he purchased one :D I want to setup Open Loop correction on his car.. big $$ engine would be good to have some insurance when he is at power cruise
his o2 sensor is more in the front half than the rear end doof :D
Anthony would you mind PM'ing me with a basic run down of setting up antilag and cyclic idle. Did the fuel map need to be changed at all?
Edited by TiTAN
good thing I don't tune my own car then...
either way... the heart-break is still there...
hey ive tuned your car!!.. Twice! Stop your whinging!
& No can do Titan.. you got stock turbo.. i am guessing it would break on your first anti lag.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
