I have a twin turbo pipe and also trying to get a Plenium from a 33 gtr, and i want to polish them up.
I want to polish out the ummm grain i guess you can call it to make it smooth and not bumpy and lumpy.
What would i need to use to sand that out of it?
Im not even thinking about getting it shinny till i have it smooth as smooth.
How?
thanks
https://www.sau.com.au/forums/topic/249350-polishing/
That pipe still looks like its gota light glaze / polish from factory.
I guess if you sand it back to the bare metal you can use Metal Polish and just polish it like the same way you polish your car body paint.
Or ask Craved (Chris), he's usually got some good tips.
Last time he suggested to me some sorta silicon spray polish.
https://www.sau.com.au/forums/topic/249350-polishing/#findComment-4325059
http://www.skylinesaustralia.com/forums/Al...mp;hl=polishing
^^ read :P
alot of work, i have since found that a scotch brite pad on a grinder will help start off the sanding/grinding process without digging into the surface or putting many deep scratches in the metal.
you are looking at alot of work though :D
https://www.sau.com.au/forums/topic/249350-polishing/#findComment-4325347
hot it with heavy sand paper to smooth it out, then hit it with something like this
http://www.australianabrasives.com/flapwheels.htm
to clear out the sanding marks in from the last step
then back to 400 grit
you can tell now why its not cheap to polish stuff haahaha
https://www.sau.com.au/forums/topic/249350-polishing/#findComment-4339282
  • 4 months later...
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
