Oil is like PS3 games, every1 has a favourite, How I chose was to read as much as I could from testers, and looked at what race teams in Japan were using too.
As long as the oil is fully synthetic, you should be ok.
Just for the record I use Motul 8100 5W 40
Live on Gold Coast, temp gets to nearly 40 in summer and 0 in winter as I live in a valley. Its good stuff, bit pricey but worth it.
Just make sure Oil & Filter are changed every 5000k's-thats the true secret
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4325378
i use motul 300v. :D
Dude you're rich :D
Motul 8100 5W40 here.
mines coming up soon too.. so I need to know what oil and oil filter to buy (stock engine ~ 50,000km)
You need 145A oil filter if your car was manufactured before 11/98. If you was after that you need Z442. They're both thread compatible but the Z442 is smaller and has finer filtration.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4331101
if your car hasnt been run on fully synthetic for the last 100000kms or something along those lines, going fully synthetic wont really make too much of a difference now. Remember when half of these cars came out, fully synthetic oil wasnt out yet. I use castrol 5-30 fully synthetic which works for me, but every car is different and wether your engine is worked or not.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4331837
I was reading something in Import Tuner magazine, talking about how this really popular engine building in the states looks after his race cars and his daily driver (a camaro). He was saying that shell full synthetic removes about 60% deposits from old motors in the first oil change. So it definately makes a difference even if you haven't run synthetic for it's entire engine life.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4331906
ouchies,
well in my R33 GST-T i used,
Semi-synthetic Oils 'cause its a waste to throw hundreds in when your dumping it out every 5thou kms'
7.5/30 winter 'cooler weather, so wont loose its velocity as bad as summer
10/40 summer 'cause oil will be hotter, so need something that will maintain itself'
personally i found 7.5/30 too noisey in summer... because its so thin and is like piss water when hot...
and considering its an older car/engine (km's)... if its to thin it can get past the oil ring n you burn a little, not that you should notice it.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4333353
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
