Oil is like PS3 games, every1 has a favourite, How I chose was to read as much as I could from testers, and looked at what race teams in Japan were using too.
As long as the oil is fully synthetic, you should be ok.
Just for the record I use Motul 8100 5W 40
Live on Gold Coast, temp gets to nearly 40 in summer and 0 in winter as I live in a valley. Its good stuff, bit pricey but worth it.
Just make sure Oil & Filter are changed every 5000k's-thats the true secret
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4325378
i use motul 300v. :D
Dude you're rich :D
Motul 8100 5W40 here.
mines coming up soon too.. so I need to know what oil and oil filter to buy (stock engine ~ 50,000km)
You need 145A oil filter if your car was manufactured before 11/98. If you was after that you need Z442. They're both thread compatible but the Z442 is smaller and has finer filtration.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4331101
if your car hasnt been run on fully synthetic for the last 100000kms or something along those lines, going fully synthetic wont really make too much of a difference now. Remember when half of these cars came out, fully synthetic oil wasnt out yet. I use castrol 5-30 fully synthetic which works for me, but every car is different and wether your engine is worked or not.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4331837
I was reading something in Import Tuner magazine, talking about how this really popular engine building in the states looks after his race cars and his daily driver (a camaro). He was saying that shell full synthetic removes about 60% deposits from old motors in the first oil change. So it definately makes a difference even if you haven't run synthetic for it's entire engine life.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4331906
ouchies,
well in my R33 GST-T i used,
Semi-synthetic Oils 'cause its a waste to throw hundreds in when your dumping it out every 5thou kms'
7.5/30 winter 'cooler weather, so wont loose its velocity as bad as summer
10/40 summer 'cause oil will be hotter, so need something that will maintain itself'
personally i found 7.5/30 too noisey in summer... because its so thin and is like piss water when hot...
and considering its an older car/engine (km's)... if its to thin it can get past the oil ring n you burn a little, not that you should notice it.
https://www.sau.com.au/forums/topic/249390-what-oil/#findComment-4333353
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
