1999 R34 4Door GTV
Genuine 80,000kms (i imported it)
Manual
Lsd
Big Turbo Brakes
Strut Braces
Gab Coilovers
Whiteline 27mm/24mm Swaybars
18x10/9 SSR Wheels
GTT Triple Gauges
Good Tyres
8 Months Rego
Immaculate inside and out.
Well Looked After
$17000 or $16000 with out wheels.
(Also i dont care what anyone thinks its worth so dont bother trying to tell me. - No Offers!)
If you are seriously interested call or text me on 0415334551.
https://www.sau.com.au/forums/topic/249427-r34-gtv/
