  • Replies 68
Posted Images
hey dude. just a question ...
seem alot of r34 owners put aftermarket wheels on was wondering what your chassis number is ? and is it visual or under the hood? if under the hood dont worry about it .
anything inside the car may be reconisable ? so if i see a r34 with stock wheels i'll check it out, plates may of just been changed
and in the pic is that just grim build up ? or a bad angle of you drivers side head light ?
head light is a bit yellowy. both r. just when i took that photo i had cleaned the left and was a comparison shot.
nothing in the car is recognisable from the outside.
feel for you but at least u have insurance!.....ive noticed /been told that cars get robbed in that vacinity all the time i havent parked there ever becos of it.... scumbags they should put surveillance cameras around there....
  • 1 month later...
Just a final update guys, insurance has paid me out and car turned up last week, well wat was left of it.
found near geelong, some dirt rd near north shore.
all that was left was a rolling shell, so chassis and axles. was nothin else left of it.
thanks for all those that were keeping an eye out but no need to do so anymore, if any1 wants it, its at pickles. lol
a bitter-sweet ending....
Let us know what ride you get next...and about the alarm you'll be installing in it!
See you at Crown, but only on carpark level 6!!!
Cheers.
Glad to hear you got your money back, although it's a huge personal blow to lose your car.
Are you getting another skyline?
Cheers.
Why level 6?
I was told, and was confirmed in this thread, ........Video camera's are on that level carpark....they can be your friend!
Haven't you been reading!!???....LOL! :P:)
Sorry, this thread is like 2 months old. My memory doesn't extend that far :)
Yeah, that is good. I heard another safest car park from the cops is the one in Fed Square, as it has video cameras on every level. Other CBD ones eg., all the Wilson ones fall down in that respect. I had to learn the hard way. Don't leave valuables in cars!
Haven't you been reading!!???....LOL! :):)
Its the level that staff park on, so its always well patrolled by security, and there are generally staff coming in and out of the building all times of the day/night. Bit more of a deterrent to nick a car from up there.
Haven't you been reading!!???....LOL! :D;)
:happy::huh: i was up there with my miss's one time ... dirty security :D
  • 2 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
