how many km's do you think the engine has seen? a compression test of only 125psi is getting on the low side, i would guess the engine is getting tired so i would be careful, especially if you arent 100% on its history.
Just a thought since you want it as reliable as possible
Engine was built at a tuning shop in japan, put in 8 years ago, I would suspect it has about 100k's on it, I was suprised at the low compression myself, but that being the case I thought maybe it had been built as a low compression engine? Idk, havent seen the internals, will be talking to a local shop about the work I want done tomorrow or on wednesday.
What's so special about not having the VCT? and it's implications re bigger turbos? Hadn't heard anything about vct being an issue before.
numbers arent *that* important, consistancy is ^
yeah i know, most places say no more than 15% variance between each pot, i dont like more than 5% myself but meh...
but in saying that 125psi is very low for a rb25, i've done a far few compression tests on skiz's and the lowest i've seen on a "healthy" running motor is 140psi. If it was mine i would just keep a close eye on it.
CR and compression tests arent directly linked, you can have a 7.0:1 CR engine still pump out 160psi of compression, a compression test is purely how the pistons/ring/valves are sealing.
Not saying its a bad idea, but like i said the title did mention reliability so smashing a larger turbo on a stock tired engine might not work out the best for that part :rofl:
    • Thank you for the feedback bro. Looks like it’ll have to stay off the road till it gets an ecu
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
