  • Replies 85
edit---TODAY--i was down at welshpool (getting my licence re-newed, no yellow sticker) there was stuff all cars there, a disgusting red celica with huge chromies, and a pig s13.
THOUGH i went in n came out in 30mins and the line hadnt moved at all. that was around, 2pm
Edited by Char
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4333523
how did you go ricca, no luck for me. got to see if my brides are adr approved, my park light reflector has to be secured, high level stop light, need tyre plark. car re weight. need to have proof that the car doesnt come with a air bag. high beams. (they worked before i left to go) got to fill out this mod form and send it through and prob have to get a engineer to look at it.
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4334598
sorry if i am jacking this thread, but how am i meant to prove that my car doesnt come with air bags
the easiest way to prove you dont have airbags is to look at your dash lights. If you have an airbag, upon igntion of the car, the airbag light will come on for a brief few seconds as a self check. If there is no airbag light at all on the dash...the car never came with it.
Edited by ZXY
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4335789
mmm when i got a yellow and went to the pits i went to the gosnells one *i had a yelloow for a T wing* i got this guy with like skin disorder and he raped me :? saying my suspension is wayyy too hard and couple of other stpuid stuff so i got my mom to take my car over at welshpool and it was done in less then 10 secs :) so yeah if i was to get a yellow again ill get my parents to take car over LOL
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4336067
Well thought i give an update.
I have since my last Check installed a new
Immboiser!!
inner toe arm
fixed the Suspension
and made a bracket for the Zaust
Heading over the pits on Monday not sure where yet i have got a friend which is a Engineer and getting his Cert to Clear his own cars
he would be taking it down so he can talk the talk!!
So hope all goes well!
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4352960
where would the engine number be on the 26, the inspector couldnt find it cause he said the turbos are in the way
Exactly where he's looking. There's a little bit of the block that sticks out, on the passenger side, up against where the gearbox bellhousing bolts onto the block.
He might need to use his little bendy mirror and get at it from the underside..
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4354713
actually found the engine number, i guess on a 26 its different, its directly under the top radiator hose on the block
lol fair enough, they probably moved it after they realised they'd put a bunch of turbos and stuff in the way :)
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4355601
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
