  • Replies 57
Yeah the defect happned on stud road rowville just outside stud park.
Anyways i went into knox police station the other day to see if i could get it extended and the guy made a few phone calls and told me the only person who could extend it was Pettit himself, turns out pettit is on Holidays till the 3rd so from the 28th to the 3rd there is not a hell of a lot i can do about it,
My skyline is a S1.5 with drivers airbag, not having much luck finding a engineer working though the chrismas break, a guy in eltham from Torque Torque apparently does alot of work with imports. but he isnt back till the 15th of Jan.
Does anyone know of a Wreckers in the eastern suburbs where i can pick up a front Rio bar which i stupidly cut (now obviously have to replace.
The up side of the Defect is that i dont have to get a RWC just the V.A.S.S cert. two back tires and a new front number plate.
Thanks for the Help
what was wrong with your number plate?
The number plate had been previously cut in one or 2 of the corners hardly even noticable, it was even like that when i bought the car so it must of passed the Roadworthy back then not sure that the laws have changed about having a tiny bit of number plate missing.
The law never changed. It's just some people aren't as anal about it.
Biggest crock of shit ever. Once pettet reports it its not in his power to allow you an extention. That has to be sorted with the EPA. So give the EPA a call and ask them.
This is the sort of stuff I want to hear at christmas, not.
Fair enough you have some illegal mods but he gave you that defect knowing damn well you were gonna have one hell of a time finding an engineer at this time of year, he gave me 3 weeks at least when I got done.
Anyway hope you get it sorted.
The defect is, he didnt say anything about EPA here...
VASS does not cover RWC
VASS are approving vehicle modifications/integrity, the general road worthyness of the car (basic things like oil leaks, boots, etc etc) are what your local VicRoads approved mechanic does.
Is it at all possible to bypass the VASS certificate,
because it looks like the only way its going to get done is if i put the SMIC back in and take my car to a panel beaters to get the hole welded in and painted over the top Thus by passing the VASS?
does anyone know if this is correct? Because from what i have been told a S1.5 with drivers airbag will no way get a VASS certificate because of air bag sensor so getting a VASS is really not an option for me Except on the infringment it says VASS certificate must be supplied to remove the defect, im so confused about the whole situation.
if you've been noted down for a VASS, id fully imagine you'd need to get one.
Fixing the problem is half the step, getting the VASS to prove you have fixed the problem is the next step
A panel beater isn't a VASS engineer, nor can they issue one
If you read the link on the first page, which is again below, it covers it.
http://www.skylinesaustralia.com/forums/Im...tml&hl=hole
I don't understand what's confusing you. You know you need to get it fixed, you know you need a VASS.
So what's still the issue exactly?
Well i was confused about deff needing a Vass, But i called Vicroads and a guy there told me that i can put it back to stock and get something in writing from the panel beater saying the hole has been covered up thus no longer needing a VASS which is what i thought.
got the person from vicroads details just incase it is ever challenged?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
