  • Replies 57
Yeah the defect happned on stud road rowville just outside stud park.
Anyways i went into knox police station the other day to see if i could get it extended and the guy made a few phone calls and told me the only person who could extend it was Pettit himself, turns out pettit is on Holidays till the 3rd so from the 28th to the 3rd there is not a hell of a lot i can do about it,
My skyline is a S1.5 with drivers airbag, not having much luck finding a engineer working though the chrismas break, a guy in eltham from Torque Torque apparently does alot of work with imports. but he isnt back till the 15th of Jan.
Does anyone know of a Wreckers in the eastern suburbs where i can pick up a front Rio bar which i stupidly cut (now obviously have to replace.
The up side of the Defect is that i dont have to get a RWC just the V.A.S.S cert. two back tires and a new front number plate.
Thanks for the Help
what was wrong with your number plate?
The number plate had been previously cut in one or 2 of the corners hardly even noticable, it was even like that when i bought the car so it must of passed the Roadworthy back then not sure that the laws have changed about having a tiny bit of number plate missing.
The law never changed. It's just some people aren't as anal about it.
Biggest crock of shit ever. Once pettet reports it its not in his power to allow you an extention. That has to be sorted with the EPA. So give the EPA a call and ask them.
This is the sort of stuff I want to hear at christmas, not.
Fair enough you have some illegal mods but he gave you that defect knowing damn well you were gonna have one hell of a time finding an engineer at this time of year, he gave me 3 weeks at least when I got done.
Anyway hope you get it sorted.
The defect is, he didnt say anything about EPA here...
VASS does not cover RWC
VASS are approving vehicle modifications/integrity, the general road worthyness of the car (basic things like oil leaks, boots, etc etc) are what your local VicRoads approved mechanic does.
Is it at all possible to bypass the VASS certificate,
because it looks like the only way its going to get done is if i put the SMIC back in and take my car to a panel beaters to get the hole welded in and painted over the top Thus by passing the VASS?
does anyone know if this is correct? Because from what i have been told a S1.5 with drivers airbag will no way get a VASS certificate because of air bag sensor so getting a VASS is really not an option for me Except on the infringment it says VASS certificate must be supplied to remove the defect, im so confused about the whole situation.
if you've been noted down for a VASS, id fully imagine you'd need to get one.
Fixing the problem is half the step, getting the VASS to prove you have fixed the problem is the next step
A panel beater isn't a VASS engineer, nor can they issue one
If you read the link on the first page, which is again below, it covers it.
http://www.skylinesaustralia.com/forums/Im...tml&hl=hole
I don't understand what's confusing you. You know you need to get it fixed, you know you need a VASS.
So what's still the issue exactly?
Well i was confused about deff needing a Vass, But i called Vicroads and a guy there told me that i can put it back to stock and get something in writing from the panel beater saying the hole has been covered up thus no longer needing a VASS which is what i thought.
got the person from vicroads details just incase it is ever challenged?
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
