PLEASE CALL ME ON 04301 487 92 if u have any questions on any of these parts
all parts are located in NSW fairfield
GT3076R TURBO KIT = $4000
TURBO: GT3076R
*also comes with braided line for oil return*
TURBO: is in very good condition, no oil leaks, no need of rebuild *ready to bolt on*
EXHAUST HOUSING: .78 divided exhaust housing (twin scroll / split pulse)
EXHAUST HOUSING: V BAND flange for dump pipe
EXHAUST HOUSING: ceramic coated
EXHAUST MANIFOLD: exhaust manifold is made from steam pipe and comes with full life time warranty
EXHAUST MANIFOLD: is also design around the SR20 1,3,4,2 firing order. cylinders 1 and 4 are divided from 2 and 3
EXHAUST MANIFOLD: is design to work with a divided twin scroll split pulse exhaust housing
EXHAUST MANIFOLD: ceramic coated
EXTERNAL WASTEGATE: Genuine TiAL 44mm
EXTERNAL WASTEGATE: comes with scream pipe
DUMP PIPE: made to suit V band exhaust housing
DUMP PIPE: made from stainless steel
COMES WITH EVERY THING U SEE IN THIS PICTURE
RB25 gearbox with sr20bellhousing = $3100
comes with one piece tailshaft already modified to suit
comes with gear stick
comes with slave cylinder
basically comes with every thing need
gearbox still in very good condition and very strong not making any funny noise at all
R32 GTR shell, $4000
car is still repairable
damage is done to driver side of car
comes with standard R32 GTR rear end
comes with dash, carpet and all the interior
R32 GTR X-force Cat Back exhaust system = $300
DSC00610.jpg]
R32 GTR front and rear brakes with master cylinder = $1000
front brake pads = VN endless NEW
front brake disc in good condition and does not need any machining at all
rear brake pads standard but dont need replacing as they still have heaps of meat left on them
rear brake disc still in good condition and dont need any machining
IM SORRY BUT I DONT HAVE A PICTURE OF THE BRAKES YET, I DONT WANT TO START STRIPPING THE CAR UNLESS I KNOW IVE GOT THE PARTS SOLD
gizmo shift light (blue) 2 stage shift light = $150
i dont realli have a good picture of this item but u can kinda see it in this picture
its just sitting near my steering wheel
SR20VET cylinder head compete = $2000
VERY VERY VERY RARE
comes with intake and exhaust cams, rocker arms, rocker cover, crank angle sensor, intake and exhaust manifolds basically the whole top half of the engine
SR20V P12 Primera CAM SHAFTS BRAND NEW FROM NISSAN = $700
SR20VE (20V) neo VVL
Intake cam
Low duration: 228deg
Low lift 10.10mm
Low center angle: 114deg
High duration: 278deg
High lift: 12.00 mm
High center angle: 114deg
Exhaust cam
Low duration: 244deg
Low lift: 8.30mm
Low center angle: 106deg
High duration: 280deg
High lift: 11.15mm
High center angle: 108deg
SR20VET bottom end competer = $1500
comes with pistons, rods, crank shaft basically comes with every thing
splitfire coil packs to suit S15 BRAND NEW STILL IN THE BOX NEVA USED = $600
apexi VAFC BRAND NEW STILL IN THE BOX NEVA USED = $400
controls VVL / Vtec
MSD 1000cc top feed injectors = $500
4 injectors
SARD 800cc top feed injectors = $500
4 injectors
bosch 023 fuel pump rated at 700hp = $200
Bride Zeta II bucket seat with rail = $800
Recaro SR3 Passenger & Driver side $1500
Rails suit: R32, R33, R34 GTST and GTR
in very good condition no holes or any thing like that
will modify rails to suit S13/S14/S15 free of charge
Cusco Coil Overs With Swift Springs = $2000
suit R32 and R33
OS GIKEN twin plate clutch = $1000
suit SR20 5 speed gearbox only (suit S13 and S14 gearbox)
not slipping at all and still in very good condition
will work with SR20 bell housing RB25 Gearbox im selling
Power FC D jetro to R32 and R33 GTR RB26 = $1700
comes with all map sensors and harness
these are very rare now
Edited by STR8E180
https://www.sau.com.au/forums/topic/250094-garage-sale/
  • 8 months later...
TURBO: GT3076R
DSC00610.jpg]
VERY VERY VERY RARE
Intake cam
Low lift 10.10mm
High lift: 12.00 mm
Exhaust cam
Low lift: 8.30mm
High lift: 11.15mm
controls VVL / Vtec
4 injectors
4 injectors
suit R32 and R33
is the power fc for a bnr32 and is the price negotiable
Thanks
https://www.sau.com.au/forums/topic/250094-garage-sale/#findComment-4801478
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
