Hi i have to replace my rear shocks on a r33 gts-t series 2 skyline it appears that i might have to remove rear seat would i be correct with this asumption or am i way off track any info would be helpfull as i dont have a repair manual thanks Sam............
P.S. I hope i have asked this question in the right section as it is my first post and im new to skylines
https://www.sau.com.au/forums/topic/250112-r33-coilover/
Yeah that is correct, you will have to remove the rear seat and parcel shelf to get to the bolts.
Hi thanks for the reply i sort of worked it all out eventually i have the new shocks installed now all is good
Sam.....
https://www.sau.com.au/forums/topic/250112-r33-coilover/#findComment-4340617
