hi guys up for sale i got a damaged gearbox that will suit a rebuild, i think may be good for parts, i was driving this car in my ownership for 3years and just decided to let go on me, 4th gear just started crunching about 2months ago, on high revs 3rd gear would be a problem most of the time, last night went out in the gtr, took off and we snapped in 3rd gear and there was no 3rd then we tried going to 4th there was also no 4th, only gears we used to get home were 1st 2nd and 5th, now just went into the garage and strated the gtr and gearstick is stuck in 3rd gear and doesnt want to come out, gearbox is still in the car so any inspection is welcome, im about to purchase a r33 gtr gearbox for the car so all this would be doing just takiing room and making a mess in the garage
NOTE- GEARBOX WILL NEED A REBUILD OR CAN USE PARTS OT OF IT BUT I DONT SEE WHY YOU WOULD
price $280
located in melbourne northern suburbs
cheers tony
https://www.sau.com.au/forums/topic/250193-r32-gtr-gearbox/
Interested in buying a stuffed box for some parts. cost to freight to brisbane?
hey mate pm me your postcode and i will chase it up for you but i seriously dont think it wil be cheap to send off mate as itrs really heavy, anyway pm me your details and a contact
cheers tony
https://www.sau.com.au/forums/topic/250193-r32-gtr-gearbox/#findComment-4341256
hey guys this gearbos is still available but one of the parts has been taken out and sold sepertaly so will sell the box for $180, and from my mechanics point the folks or something are stuufesd in the box but it is very good to use for parts or to rebuild,
the part that has been sold is the plate that the main shaft goes through and covers the bearings inside the bellhousing, the one that also mounts the pivot bolt or else everything is there
NEED IT GONE
cheer tony
Edited by GTRBOS
https://www.sau.com.au/forums/topic/250193-r32-gtr-gearbox/#findComment-4360284
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
