hello
well i will be undertaking a welding course in February, and currently have a project 31 so i thought having a welder would be a handy thing to have for those little fabrication jobs that come up with DIY projects. I have a little bit of MIG and stick experience but as far as welding intercooler piping, exhausts and all that sort of stuff, i figure having a TIG would be most beneficial.
There are shitloads of second hand welders for sale in the local trader, so what kind of brands should i look for, with what kind of features? i dont want to spend more the 1k either
preferably less than that if possible!
cheers
https://www.sau.com.au/forums/topic/250299-tig-welder/
for that kind of price range, i cant really suggest anything.
Might be better if you list what there is available, since most TIG machines are $4K+.
all you really need for alloy is it capable of AC welding, and about 120Amps- but you might be fighting the machinea bit to get good.
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4337447
yer like i said im pretty much after brands and functions as there are heaps for sale second hand below 1k.....just a shitload of different brands etc etc
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4337874
if you can handle not being able to weld Alu you should be able to get something. i've got a $400 Arc welder that i've got a tig torch/gas for etc, will be fine for most stuff. i dont rkn you really need a big $4k machine for the basic stuf you've listed
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4337946
Hey mate if your not going to use it much just get a cheap one off ebay, look for the duty cycle at min 50% and high frequency start up, and you would want an inverter model much nicer on 240 volt oh and a foot controler ( controls your amps like a throtle)
My mate got a cheap one and its not to bad really if your new at the game you would love it from memory he paid under a grand,
like what was said before if you want something nice your looking at 4k up my kemmpi cost just under 5k and is f*ckin great but thats what i do for a livin, one more thing if you can find one with a pulse on it even better good luck buddy :P
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4346148
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
    • They're not rebuilt Racepace items. They were mint. From memory the were ex display stock that I bought off yahoo and he ran....from memory he barely used the REs when he replaced them with a set of Tein RS If have been stored correctly and not leaked fluid then they will be mint   As an observation the Racebuilt rebuilt Tein RA/RE/RS were a better street/club/track package. Really nice on the street and did good numbers at the track.  I think the factory Teins wont match the Racepace valving on the street but would be in the same window of performance on the track... albeit firmer
    • The one time that Clippy is actually useful!
