what did you get done for?? and where... ive got sum spare h1 globes and fitting plates.. jsut a matter of pulling off your pos and neg wires off your ballast (not illigal to have random wires) weve got sum stock suspension, stock coolers, and if they wona b hell priks might have to get our turbo mission on
yeh intercoolers are fine as long as:
1. reo bar isn't hacked up
2. everything tight and nothing hanging under the bumper
3. the cut holes for the piping are neat and treated so they don't rust
Guest CleanAndSimple
Well when i went to regency, took it totally back to stock, replaced suspension, pretty much all bushes, all exaust mounts, everything. and they still got something on me.
my advice, take off what you can. and just go, and get the list they give you! then they cannot search for anything else, got that advice from a compliance shop!.
otherwise u just end up spending like 4k like i did on parts etc, to just take them off and put brand new parts in shed after regency.
  • 3 weeks later...
ok so i went in today for my inspection. as i thought they did me for my turbo not to fussed about that as it is not stock and i will cop no i just have to put my old one on. the two other 2 things i got done for which im pretty pissed off about is my BOV (which is plumbed back into its original position) was classified as a defect as its not the original one. he didnt care that my old one leaked and that my car backfired all the time. the other thing im a bit suprised about is that i have to put on my old stock boost controller as having the vacume line go from the wastegate to the intercooler pipe was not good enough.
the things i didnt get done for were my front mount, my 4 piston front brakes, my exhaust which funnily enough he only did by ear.
now for the hillarious part. once i finish this write up im about to start removing and replacing my turbo. on my defect notice it states that i have to have an O.E.M certified report. this means that once i put the old turbo on i have to go to nissan and have them certify the turbo is the standard one. i thought that was the whole reason we take our car to get inspected. if they cant tell if it's the standard one on there how can they tell if i don't have a standard one. now i have to ring around all the nissan dealerships and see if they can do this or not.
just the ang the mob i brought the car from and they will certify it after i change it at a cost of $110. nissan said they would only certify it they supplied me with a (BRAND NEW) one. i politly hung up and swore afterwards
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
