hi mate,
still u got the car 4 wrecking. im looking for ur stering wheel and turbo...
Hey dudes. I picked up another R33 thats just asking to be parted out. it was hit up the arse on the right hand side so the front end is still good.. the rear quarter, right tail light, bootlid and rear bumper are gone though. More pics will be added in the next few days - Pm me for anything specific
R33 Series 2 motor:
Approx 85,000 ks, great compression- 155/160psi across all cyls. Includes turbo & wiring loom - $1800 ono
4sp Auto gearbox - $500
Front end stuff:
S2 front bar -SOLD
S2 grille -SOLD
Front guards - $100 each
S2 headlights - $500 firm pair
S2 bonnet - $300
A/c fan - $80
A/c condenser - $150
Radiator & shroud - $100
Front reo bar (uncut) - $150
Radiator support - $150
Engine bay stuff:
S2 AFM (pink sticker)- $90
R33 aircon compressor - $100
R33 power steering pump - $100
R33 alternator - $80
Fuse box lid - $20
Stock cat converter - $50
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $80
Stock SMIC piping - $50
Stock sidemount intercooler - $40
ABS pump - $100
Exterior & suspension/brakes:
Set of R33 gts-t stockies with kuhmo tyres. almost brand new / 90% tread - $300
5 stud space saver - $50
Side mirrors - $50 each
Tail light (left hand side) - $50
Rear SKYLINE garnish (silver) - $50
Bm-44 ABS brake master cylinder - $80
Stock suspension, complete set - $200
Front lower control arms - $60 each
Front upper control arms - $40 each
Front hubs - $80 ea
Rear lower control arms - $60 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Auto ABS 4.3 diff - SOLD
Driveshafts $60 pair
Rear upper arms - $50
Front calipers - SOLD
front rotors (almost brand new) - $50
rear calipers - $150 pair
Rear rotors (almost brand new) - $50
Interior stuff:
Drivers door window switch - $80
Drivers window switch surround - $40
Drivers door motor - $80
Passenger door motor - $50
Door trims - $50 each
S2 Dash surround (with clock, hazard switch etc) - $80
Instrument cluster (auto) ~85,000ks - $100
Auto gear stick surround - $40
Under dash piece (covers fuse box) $30
S2 dash pad (with passenger airbag & panel) - $400
S2 Steering wheel with airbag - $250
Centre console - $60
Front seats, good condition - $200
Rear seats, good condition - $50
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
If theres any stuff not listed send me a PM and i'll get back to ya. Located in sydney for pickup or I can post almost anything at buyers expense :thumbsup:
  • 1 month later...
  • Replies 56
Posted Images
  • 3 weeks later...
Hey phatlavish im interested in buying the series 2 dash surround and also the gear selector surround as well if you have them. If these parts are in good condition i would like to buy them this weekend please. Can you please sms me your mobile number and i will call you back to arrange pick up. I wont have access to the net over the weekend.
Manuel 0406747726
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
OK cool thanks. I'm still kinda 'shopping' around for one so I'll defintely let you know later on today if I'm genuinely interested. Is that the best price you can do also? Appreciate the reply.
No worries, Pm me if ya like (when ya get 10 posts). And yeah that's the best price
cheers
you still have bits left of this car?? , i need the dash facia thingy with the clock etc in it (i don't need the clock but i'll take it anyway) the auto surround , the snow/power switch in the console , the front left guard and the console lid if you still have it all :D
edit , i'll pm :)
Edited by toffy
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
