:happy: So, 2 weeks on and no news ? BTW, do you still have our money or do they ? :ninja:
Your money is safe with me. I never hand it over to them until they charge my account.
I need to play it safe for everyone's sake.
What I'm worried of is something has happened since the whole economy went into resession.
I rang and didn't get through yesterday, only a voice mail, will try again some time today.
  • Replies 447
Whats the chance that they will arrive before the 13th? Ive got a track day on the 14th and one of my front ones is cracked so will be in real shite if they dont show up...
I've left a message on their voicemail asking my contact to call me back. If they process and ship everything by Mon-Tue next week then there's a chance you'll get it before 13th, if not then it will not make it.
Surely SAU alone would keep them in the black :)
wow still doing these group buys lol. bought some rotors from you over a year ago.
can you pm me a price on R33 non turbo 4 stud rotors, slotted if available, if not then just normal
I'll check...
Just a word of caution, with heavier vehicles you may notice a lot of rotor wear on the fronts. My front rotors lasted the same time as the pads.
I have read that the RDA rotor are designed and manufactured to be a little softer to give better bite and stopping power but at the expense of rotor life.
They're cheap anyway so why not............
Interested to know what car have you got when this happened. I had someone said their 300ZX front rotors (gold passivated) also wears out very quick.
Oh and was yours slotted or the gold passivated grooved/dimpled?
I personally have used it on the front of R33 Gtst without any premature use (even tracked it - with greenstuff which is not really for track pads),
and currently on a V35 with redstuff pads - but I have only done 5000km in my V35 so hard to say...
So perhaps the gold passivated one is 'softer' than slotted...
This happened on my VX Calais which is quite a heavy car (read "slug") :P . The V35 is only 100 odd kg lighter so could be a candidate, although I've read it is a much better balanced vehicle so may not suffer the same fate.
the rotors were the slotted non-passivated. I've got the passivated slotted on now and well see how that goes. Has anyone tried the moly rotors?
Edited by mosoto
I am trying on the passivated rotors. If it's right then it's softer than the slotted but so far I haven't had any issues yet.
But again, V35 Skyline is 1590 kg and in a coupe the weight distribution is 53/47 front to back (in sedan it's 52/48).
It has 296mm front and 292mm rear in touring trim (non brembo) or 324mm front and 322mm rear in track / brembo form.
I have the later (brembo) size
A guy in his 300ZX said his car has 80/20 brake bias front to rear, unsure of static weight distribution on 300ZX though,
anyone know what are the brake usage on 300ZX? Worn his gold passivated rotors fairly quick as well.
The Z32 turbo has 280mm front and 297mm rear, same sizes like R32 Gtst, but I'm sure the Z32 with VG30DETT engine weighs
a lot more at the front than a single turbo R32 with RB20DET.
R32 Gts-t weighs 1260kg manual or 1280kg auto according to my JDM brochure, 300ZX is 1460kg in hatchback
or 1560kg in convertible ( targa roof ? ) form, so it is a much heavier car with an undersized OEM brakes - in my opinion
Added: as a comparison a 1340kg (man) / 1390kg (auto) R33 Gtst which is still lighter than 300ZX is already equipped with 296mm / 297mm rotors by standard. bigger diameter would logically mean less effort required to stop the car on daily use, and logically would mean the rotor should last longer.
ive got R32 gtst front brakes on my r31 with the rda slotted rotors and bendix ultimate pads (average). been on for bout year and a half now, pads are about 40% and the rotors are lipped (only slightly though definately machinable) this is mainly street driving. so yeah the rotors arent the longest lasting rotors there are.
btw did you get prices on R33 na rotors? pretty keen..
how many kms is that? just to give a rough idea how long they will last...
my stock V35 OEM front rotors were less than minimum legal - that was I assumed 49000km never replaced from japan, on a stock pads. didn't pass RWC, I needed to get a new set. The rear was lipped but legal (machineable).
I'll check on NA R33 rotors - forgotten about it.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
