I have the following for sale;
Clarion SRW3041 12" 500W Sub in black carpeted box - $120
http://www.pbase.com/image/20718700
Phillips stereo system including 4x30W head unit, 6 stacker, 170W 6" & 200W 6x9's - $400 (never been amped - comes with manuals, card) - no pix.
Full 2 1/4" exhaust with polished tip, by Liverpool Exhausts, off an MY99 RX - $400
Polished BSA 17x8's suit WRX/Impreza, little rubber (215x45's). - $1000
http://www.pbase.com/image/20718687
http://www.pbase.com/image/20718684
http://www.pbase.com/image/20718634
Custom intake with rampod suit N/A Subaru Impreza - $130
Maroon low-style rear spoiler with brake light off '99 Impreza RX - $70
Also have original owners manual, booklet, etc for Subaru Impreza RX.
E-mail [email protected]
Located in Geelong
https://www.sau.com.au/forums/topic/25152-audio-gear17-wrx-rimsspoilerintake/
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
