These are brand new:
I have a sub for sale, i have 2 but i think i will keep one. Details are
MB Quart RWC 304 12" Dual Voice Coil 4 Ohm
It is brand new. Still in the original plastic cover.
From what i can see its only rated at 200WRMS so its very efficient.
I will also have some focal splits up for sale in about 2 weeks time when I get my new speakers which will be JL.
Im asking for about 350 but i'll consider close offers.
shipping will be about 10-15 bucks delivered to ur door the next day.
Manufacturer's RWC304 Specifications:
Copolymer Cone
Cast Aluminum Basket
Iron Ferrite Magnet
Impedance: 2 x 4ohms
Frequency Response: 18Hz - 300Hz
Sensitivity: 87db (1W/1M)
Power Range: 300 Watts Max
Recommended Enclosure Size: 1.0 Cubic Feet, sealed with polyfill
Mounting Depth: 5.58"
heres some reviews.
http://www.carreview.com/Subwoofers/MB%20Q...35_1808crx.aspx
http://www.carsound.com/reviews/subs/MBQua...rt_RWC_304.html
https://www.sau.com.au/forums/topic/25154-fs-mb-quart-subs/
vlberlina can u pm me again i've forgotten what u've offered. they are brand new in original cardboard boxes ... still in plastic ... so they dont' have no sub box.
gtt98 .. give me an extra 25 and i can do that delivered to your door 1 or 2 days delivery.
https://www.sau.com.au/forums/topic/25154-fs-mb-quart-subs/#findComment-560489
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
