Do you roughly know if you would be using the same amount of money taking into the consideration with the cost of 98RON and running E85 if you know what I am saying?
I assume Donnan can remap the injectors into the fuelmap on the standard ECU?
I'm thinking this is too much of a headcase for my liking lol :(
  • Replies 64
He might do, however I believe Mr Donnon tends to favour the Apexi PowerFC and might recommend u buy one ;P
I do know for a fact that if you want to remap a stock 32 ecu that extensively, you'll need to buy the nisstune eeprom addon ($200 for software, $220 for the installation and chip and around $80 for a consult cable) but its the most regency friendly ecu that you can use (without hiding a pfc in a stock nissan ecu housing that is ;P)... its much cheaper to get nisstune addon rather than the pfc, and there are many places that can dynotune it, morpowa, horsepower in a box, boostworks etc
Standard ECU can probably take other injectors provided they are the same latency and impedance. Provided they meet that criteria, all a tuner would need to do is lower the duty cycle of a big injector to tune it for e85, that said the nisstune/pfc will allow you to correct latency - still need low impedance injectors as far as I know, tho I'm no expert on these matters...
Regarding price - you'll be paying more as the volume loss is around 30% but you only get around 10-15% cheaper price per litre, so you'll be paying more and drinking it more BUT its cheap power and environmentally friendly (as far as performance vehicles are concerned - if you love mother nature that badly, walk)
-D
also E85 has a lower detonation factor meaning it is harder for your engine to knock
or another way of putting it the fuel is kinder to your internals
E85 has 108 ron rating ( best e85 is made from hemp) Yes hemp 115 ron
Source
Source
yeah, its kinder on the engine, the environment, not kind on the wallet - only marginally more expensive, but when you gain the 50kw odd that e85 gives you, some people (like me) would definately go for it :(
Good for street cars that can refill a lot, not so great for tarmac rally, targa or circuit due to the extra fuel changes required... they use pretty good fuel in racecars as it is, but the e85 is going to help a lot of people with emissions test over the next few years - but only if they can get more stations selling e85... it seems a logical alternative
one thing that always baffled me tho, is why we havent promoted lpg more. we have a huge proportion of supplies for lpg naturally, sure its not great for every application (and suffers from the same density loss as e85) but its something that would make fiscal and military sense - why not be self sufficient for the majority of the countries transport? means people are less affected by global economic fluctuation, and in times of war makes the country not rely on deliveries ... (sure it does paint a big 'kick me in the nuts' sign over any refinery, but thems the breaks)
same deal with nuclear power. nuclear power rocks.
-D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
