engine internals
rb25det
built 12 months ago but done low kays ,consists of
acid cleaned and prepped block, new welsh plugs etc
balanced crank to suit new rods and pistons
Eagle H beam rods
ACL Forged pistons
Jun oil drive collar
ARP crank, big end, and head studs
N1 oil pump
new R33 water pump
new tensioners and nissan belt
tomei oil retrictors
head rebuilt with tomei poncams
tomei exhaust cam wheel
new NGK iridium's
Bolt ons
ETM high mount manifold HPC coated black
gt3582r-iw with exhaust housing HPC coated black
choice of either 18 psi or 24 psi actuator.
turbo beenie
ss braided lines both feed and return.
3 inch dump with 2 inch wastegate pipe all in 316 stainless
5 inch cat
PFC with inbuilt Boost controller
600 x 300 x 80 ASE front mount
brand new bosch q45 AFM
4 inch stainless intake
FPR with gauge
044 intank setup.
Trans
fully built box from MV Automatics
2800 high stall
stg 2 shift kit
includes all new custum clutches and kevlar band etc
this is my wifes car so was only ever boosted properly on the dyno.
either seperate for parts or sell car whole.
open to offers
Hey mate
I know you probably wanna sell the car whole, but would be interested in the Transmission if you do seperate it. Pm me details on price, locatation etc.
Cheers
Brendan
Hey mate
Cheers
Brendan
no worries i will happily seperate the car if i can find buyers for a few of the major parts like manifold / turbo set up, engine , trans etc.once the big things are allocated i will strip all the parts and list prices for all the remaining mods.
I'm interested in some of the items but I'm located in the USA...do you have a problem with international postage? I have a FedEx account if that makes things easier for you. Thanks!
-Blake :P
rb25det
Eagle H beam rods
ACL Forged pistons
N1 oil pump
new R33 water pump
Short motor $3500
head rebuilt with tomei poncams $1500
tomei exhaust cam wheel (not installed) $200
new NGK iridium's
Bolt ons
ETM high mount manifold HPC coated black $1000
gt3582r-iw with exhaust housing HPC coated black $1500
choice of either 18 psi or 24 psi actuator. $100 each
turbo beenie $75
ss braided lines both feed and return. $100
3 inch dump with 2 inch wastegate pipe all in 316 stainless $200
5 inch cat $150
PFC with inbuilt Boost controller $1000
600 x 300 x 80 ASE front mount $700
brand new bosch q45 AFM $300
4 inch stainless intake $100
FPR with gauge $150
044 intank setup. $200
Trans
2800 high stall
stg 2 shift kit
large trans cooler
includes all new custum clutches and kevlar band etc $2200
rb25det
Eagle H beam rods
ACL Forged pistons
N1 oil pump
new R33 water pump
Short motor $3500
new NGK iridium's
Bolt ons
turbo beenie $75
5 inch cat $150
FPR with gauge $150
Trans
2800 high stall
stg 2 shift kit
large trans cooler
PM sent
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
