You can buy the Dump and front pipe as one. If you saw the size of the standard dump i recommend you upgrade. Best mod i did was the Dump+front pipe from just jap and the xforce highflow cat. Makes the car more responsive and come on boost sooner.
did the dump and front pipe fit stright on or did you have to modify it?
im also interested in this, at the moment i have a hks front pipe, hiflow cat and a kakimoto 3inch cat back, with a stock dump.. will it make a big difference to change the dump, i was told not to change it as it wont make a difference.. thanks
I once had just a catback exh. I decided to upgrade the dump/front/cat.
Once i upgraded it all, im not sure whether it was just me or that i lost a little bit of responsiveness HOWEVER the boost hit ALOT harder and the exh had an angrier growl to it(no cats/reso's etc). It pulled ALOT harder throughout the rev range.
Have to be careful tho as you might get boost creep, which an ebc might be needed for then.
front/dump/high flow cat and exhaust, best mod ive done. easy fit. cheap. i already had a cat back system so i saved quite abit of time and money.
my whole exhaust on an r33 gtst series 2 uses the original exhaust mounts.
just jap bell mouth front/dump 3inch, Xforce 3inch highflow cat, fujitsubo 3.5inch cat back....
  • 1 month later...
Sorry for the newbie question. My mate has a N/A R34 (2.5ltr) manual, he wants to get a high flow cat and just a muffler. What size cat should he get? Same diameter as exhaust or bigger? The stock N/A exhaust I think is 2 1/4", not sure. So 2 1/4" or 2 1/2" or 3" cat? The less cell the better yeah? Thanks for any help.
Edited by BaysideBlue
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
