in the early stages of getting together a 26/30
theory is if i mod my 32, with things that i can use on a 30 as well
i know -10 will be fairly laggy on my stock 26 but i only want to buy it once...
im aiming for (in the 26/30) bout 500hp atw with as much torque as possible, building his sucker for the hills, with stock crank and forged rod and pistons.
question in by changing the exhaust manifold will i get alot more torque??
https://www.sau.com.au/forums/topic/252061-10s/
please dont post what 'you' can get, as it makes others jealous
but can he get them with the extra dicky thingy that does some weird shit at 23,000 rpm (which is my redline in my new 3.9 stroked rb20 (questions on this new item welcome))
Edited by Dearlove
https://www.sau.com.au/forums/topic/252061-10s/#findComment-4363760
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
