1997 Nissan S14 200sx Series 2
Engine Mods
Rebuilt SR20DET by CAPA Performance
- Arias Forged Pistons and Rings (std bore)
- Shot-Peened Rods
- Clevevite Performance Bearings (mains/big ends)
- Cometic 1.2mm Metal Steel Shimmed Head Gasket
- Fully Harmonically Balanced
- Acid Dipped
- ARP Head Stud Kit
- Rocker Arm Stoppers
- Valve Guides Machined
- Supertech Viton Valve Race Seals
- Valves Faced and Seats Cut
- Precision Hydraulic lifters
- Genuine Garrett Gaskets Used
Garrett GT2871R 52trim with .64 Exhaust Housing
Tomei Poncams 256 in&exh 11.5mm Lift
Brian Crower Valve Springs
Nismo 555cc Injectors
Z32 Airflow Meter
Remapped ECU (Nistune board) by Jeff from The Speed Lab
Walbro 255 lp/h Fuel Pump
Braided Oil and Water Lines
Front Mount Intercooler 600x300x100mm
Polished Intercooler Piping
Stainless steel intake pipe
GKtech Stainless steel manifold
Exhaust Manifold Heat Shield
3" Stainless Steel Exhaust with De-cat Pipe and Flex Pipe
K&N Pod Filter
Rocker Cover Breather Filter
Turbotech Boost Controller
Silicon Radiator/Heater Hoses
Driveline & Brakes
B&N Short Shifter
Xtreme Xtra-Heavy Duty Solid Button Clutch
- 1200kg Pressure Plate
- ARP Bolts from Crank to Flywheel and Clutch to Flywheel
New Clutch Cable
Freshly Shimmed Stock Diff
Bendix CTFront Brake Pads
Bendix Advanced Rear Brake Pads
Suspension
G4 Racing Adjustable Coilovers
Polyurathane Front Bushes
New Tie Rod Ends
Front Polished Strut Brace
Wheels
Starcorp Impuls
19 x 8.5 +18 (20mm spacer)
19 x 9.5 +23 (15mm spacer)
Exterior
Vertex Front Bar (also have Uras Type 4 Front Bar)
Vertex Sideskirts and Rear Bar
Ganador Side Mirrors (painted)
JDM Clear Front Bar Indicators
Clear Side Indicators
JDM Bootlid (no holes/spoiler)
JDM Bonnet Badge
Mines Bonnet Decal
Red Painted Brake Calipers
White Headlight Extended wattage High and low beam globes
Rolled guards all round
Interior
Black Leather Interior
Momo Steering Wheel
Momo Gear Knob
Apexi EL Mechanical Boost Gauge Mounted on A-pillar
APEXi Rev/Speed Meter
Carbon Fibre Trims
HKS Turbo Timer
New Alarm System
Genuine 200sx Floor Mats
Stereo
Kenwood Head unit
Kenwood 6" Splits in Front Doors
Kenwood 7x10's in Parcel Shelf
Kenwood 4 channel amp
Power
257.8 rwkw @ 22psi
The new forged motor has only done 7000km's and most of the mods were done at the same time.
The rims, ganador mirrors, new bootlid, nistune remap, cams, exhaust system, walbro fuel pump, front mount intercooler, rocker arm stoppers, braided oil and water lines, silicon heater hose kit, cometic metal head gasket, new precision hydraulic lifters, front bendix pads, Supertech Viton valve race seals , valve maching and head reco were done less than 1000km's ago.
The engine was inspected while the head was off and everything was 100%.
Car is mechanically A1 and I'm only selling due to losing my license and not being able to drive it. Never been on a track or been in an accident. I've owed it for the last 3 years.
I've spent over $20,000 on the car to get it to where it is now, have reciepts for the work done and a excel spread sheet with all the mods and costs.
Engine was built by Scott Hardwick from CAPA Performance.
Car is located in Adelaide.
$21,000 ONO
Tim - 0433382466
https://www.sau.com.au/forums/topic/252214-nissan-s14-200sx-series-2/
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
