Custom im guessing.
Have you tried your local car audio specialist man?
They should be able to help, custom ones shouldnt cost much .
They take the specs of your sub, punch it into a program ( forget what it was called ).. they then get the specs for the required box and build it to the exact volume. Just peices of wood and fabric.
MRXTCZ
If you are in Melbourne, try looking up Custom Car Sound for the original item. They bring in all the american brands in and supply them out to the stores like JB, Strathfield, etc. Where abouts in Melb are you? If you want custom, try G.L. Pro Sound in Keilor, Tower Audio in Oakleigh or Freeway Car Audio in Malvern.
i dont mind travelling, would prefer the original box and was hoping it would fit R32 boot under the parcel self, thats why i didnt get the 12"..
if it doesnt fit under the parcel shelve, ill go custom and get it fitted flush.. just looking on custom car sound website now.. tnx
If you dont mind travelling and you want custom, go the Tower Audio option. They have done some awesome work. Im sure if you give Custom Car Sound a call, they can help you out. Ive done my setup with kicker components (except for treble amp) and they were very helpfull. Just had to go through JB to pick it up, but went to see Mayouf at JB Epping and he gave me some awesome deals. Great bloke to deal with.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
